Page 1 of 7
SolarEdge via LAN interface
Posted: Thursday 08 June 2017 0:19
by HF1972
After adding hardware (Setup -> Hardware -> SolarEdge via LAN interface), it does not want to appear under Setup -> Devices.
What am I doing wrong
Re: SolarEdge via LAN interface
Posted: Thursday 08 June 2017 6:57
by mrf68
Posted: Thursday 08 June 2017 10:19
by HF1972
I think I've done everything according to the roadmap.
RPI 3B RASPBIAN JESSIE
Domoticz V3.587
See screenshots
Why does there not listening any thing on port 2222
pi@raspberrypi:~ $ netstat -an |grep 22
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 192.168.106.8:22 192.168.106.14:53647 ESTABLISHED
tcp6 0 0 :::22 :::* LISTEN
unix 3 [ ] STREAM CONNECTED 10622 /var/run/dhcpcd.unpriv.sock
pi@raspberrypi:~ $ netstat -an |grep -i LIST
tcp6 0 0 :::8080 :::* LISTEN
tcp6 0 0 :::443 :::* LISTEN
tcp6 0 0 :::6144 :::* LISTEN
unix 2 [ ACC ] STREAM LISTENING 6154 /run/systemd/private
unix 2 [ ACC ] SEQPACKET LISTENING 6176 /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 10383 @/tmp/.X11-unix/X0
unix 2 [ ACC ] STREAM LISTENING 6180 /run/systemd/journal/stdout
unix 2 [ ACC ] STREAM LISTENING 10384 /tmp/.X11-unix/X0
unix 2 [ ACC ] STREAM LISTENING 11393 /tmp/ssh-dlHzru82H4tO/agent.636
unix 2 [ ACC ] STREAM LISTENING 9015 /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 9018 /var/run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 11647 /tmp/.menu-cached-:0-pi
unix 2 [ ACC ] STREAM LISTENING 8017 /var/run/dhcpcd.sock
unix 2 [ ACC ] STREAM LISTENING 8019 /var/run/dhcpcd.unpriv.sock
unix 2 [ ACC ] STREAM LISTENING 1692 /run/user/1000/systemd/private
unix 2 [ ACC ] STREAM LISTENING 9674 /tmp/.pcmanfm-socket--0-pi
unix 2 [ ACC ] STREAM LISTENING 11398 @/tmp/dbus-zNZIoD6Mr6
unix 2 [ ACC ] STREAM LISTENING 10572 /tmp/ssh-nDsUlVkVJRup/agent.738
Posted: Thursday 08 June 2017 19:49
by antwan
SolarEdge via lan does not work for 6 Months. Use SolarEdge via Web API instead.
Posted: Thursday 08 June 2017 20:30
by HF1972
I'm assuming that it has worked in an older version of Domoticz.
Can I use an older version? And so which version would this be?
If i'm right, the LAN method has more options than the API method, is this correct?
Is there a solution to fix this in the new version of Domoticz?
Posted: Thursday 08 June 2017 22:09
by antwan
Reverse engineer the new protocol solaredge has implemented. Me and gizmocuz allready spent 100 hours on this, now someone else turn.
Posted: Sunday 11 June 2017 0:12
by TheBassman
BTW, My SolarEdge system was installed a month ago, and the URL for the data log is prod2.solaredge.com port 22222.
Thought I would pass this along in case it has any bearing on the module. Maybe it's where the new formatted data must be uploaded?
Posted: Thursday 31 August 2017 21:21
by thecosmicgate
Some updates regarding this issue ? I would love to monitor the solar edge system using the (W)LAN option
Posted: Friday 08 September 2017 10:18
by thecosmicgate
Silince ;( no updates / fixes
Sent from my SM-G935F using Tapatalk
Posted: Friday 08 September 2017 10:35
by freijn
I would be VERY interested TOO !
I love reverse engineering, I do have some coding knowledge ( Old plain C ) but can work with python and that sort of stuff.
Can we create a new team trying to get this to live again ?
Who else can help ?
Cheers,
Frank ( netherlands )
Posted: Friday 08 September 2017 16:09
by thecosmicgate
freijn wrote:I would be VERY interested TOO !
Who else can help ?
Cheers,
I would love to help where possible (also the NL)
Posted: Sunday 10 September 2017 22:01
by thecosmicgate
How can we " reverse engineer" this ?
Posted: Monday 11 September 2017 8:33
by freijn
afaik and understand the process the SolarEdge is "chatting" home and dumps al the data there.
So if we caputure the stream of data and then decode the messages we can putting them in our own database instead of SolarEdge home db.
I have understood it worked before so major work has already been done, but if SE decided to move a message or rename it, the previous reverse engineering is lost and won't work anymore.
Makes sense?
Greetings Frank
Posted: Tuesday 12 September 2017 14:44
by thecosmicgate
freijn wrote:afaik and understand the process the SolarEdge is "chatting" home and dumps al the data there.
Makes sense?
Greetings Frank
Maybe the people who already reverse engineered this could help with this. But an can't find out who they where
Posted: Saturday 30 September 2017 9:59
by thecosmicgate
@freijn: did you make some progress
Posted: Monday 02 October 2017 21:27
by freijn
I have no Clue where to start....
Anybody can point us in the correct direction please?
Posted: Tuesday 03 October 2017 9:46
by thecosmicgate
@antwan / @Gizmocuz maybe you could help us start the research of re-intergration of this function
Posted: Wednesday 25 October 2017 21:04
by ErnstPD
What kind of connection do I have to use to edit the SolarEdge inverter with the SolarEdge configuration tool version2?
Is it possible to connect over the LAN interface or is it only possible with a serial connector or USB? And what kind of cable do I have to get?
Posted: Saturday 27 January 2018 19:14
by McMelloW
freijn wrote: Monday 02 October 2017 21:27
I have been searching on this subject for sometime. If you have a TCP and LAN cable connection on your SolarEdge inverter this
document might be interesting.
A test with the
Shortbus Modbus Scanner tool shows it is possible to read/scan the output of your SolarEdge via the local-ip port 502. This proofs that reading your SolarEdge via TCP configuration works. See pages 7/8 of the above mentioned document.
I hope this gives you a starting point
Posted: Saturday 27 January 2018 23:29
by McMelloW
Here is another starting point for you.
Finally, I have a working solution to get data direct from my SolarEdge The
Sunspec-Monitor Although it is a Perl script it works OK. Next step is to get it running every 5 minutes within Domoticz.
It reads the complete registers and this is the output
INVERTER:
Model: SolarEdge SE3500
Firmware version: 3.2173
Serial Number: 73xxxxxx
Status: SLEEPING
Power Output (AC): 0 W
Power Input (DC): 0 W
Efficiency: 0.00 %
Total Production: 165.755 kWh
Voltage (AC): 234.30 V (50.01 Hz)
Current (AC): 0.00 A
Voltage (DC): 0.50 V
Current (DC): 0.00 A
Temperature: 30.95 C (heatsink)
I think this is more like it, instead of being depended on the SolarEdge website
