Page 1 of 2
Set security armed/disarmed by switch
Posted: Monday 17 February 2014 21:05
by Niekoesj
Just purchased a keychain remote controller
http://www.klikaanklikuit.nl/shop/produ ... -akct-511/
I tried to build a event that if the remote is presses I, the security turns to "Armed". And if i press O, the security gets disarmed.
But it seems that the security panel can't change from status by switches or other conditions?
Re: Set security armed/disarmed by switch
Posted: Thursday 20 February 2014 6:18
by Luuc_a
You have to do this with a lua script
Example
if (devicechanged['<Switch Name>'] == 'On') then
commandArray['Security panel'] = 'Arm Away'
if (devicechanged['<Switch Name>'] == 'Off') then
commandArray['Security panel'] = 'Disarm'
Return commandArray
Posted: Thursday 20 February 2014 12:53
by Niekoesj
Hi Luuc_a !
Thanks for the tip, i'll check this later today to see if this works
Posted: Friday 21 February 2014 19:52
by Niekoesj
I tried this but it ain't seems to work yet
print('this will end up in the domoticz log')
if (devicechanged['Sleutel 1'] == 'Group On') then
commandArray['Security'] = 'Armed Away'
commandArray['Security'] = 'Disarmed'
Return commandArray
Posted: Sunday 23 February 2014 14:38
by Vicne
I'm currently playing with the same feature (using revision 1522) and I admit the behaviour is somewhat puzzling.
What I see is that :
- the two armed statuses should be spelled "Arm Home" and "Arm Away", like Luuc_a wrote, not "Arm
ed" like you did. On the security panel screen, both expressions are present:
http://screencast.com/t/TYK6fW4VVomO
- although the button on the panel is named "Disarm" and X10 security send the "Disarm" command and the status displayed on the security panel is then "Disarmed", the actual status of the security panel in disarmed mode is "Normal", not "Disarm"
- of course, the name you gave the Security Panel in your UI should match the one in your scripts. It seems domoticz can handle only one device of type "Security panel", so no matter the name you give it, if you open it using the "/secpanel" page (by clicking on its icon on the dashboard or via Setup > More Options > Security panel, you will change the status of that only security panel
- note that when switching to "Arm Home" or "Arm Away" (using the Security Panel UI or a lua script), there will be a delay before it triggers any script or changes state in the UI, depending on your settings in Setup > Application Settings > Security Panel > Delay. There is no delay when disarming however.
- since revision 1.1023, there are 3 types of lua scripts: "device", "time" and "security". When I arm/disarm using the control panel, both the "device" and "security" scripts are triggered (ok, well, ...). However the security one still logs the Security Panel in the previous state
! So if you change from Normal (Disarm) to Arm Home, the security script receives it in "Normal" state while the device script receives it in "Arm Home". I think that is a bug.
If others can confirm this behaviour, i think it would be interesting to file a bug for the last point that renders security scripts useless...
Hope it helps
Vicne
Posted: Sunday 23 February 2014 16:55
by Vicne
More observations:
The
wiki says
The state of the Domoticz built in security system can be checked via globalvariables['Security']. This will return "Disarmed", "Armed Home" or "Armed Away". It is not a true device, so it will not be picked up as one in a device script. Use a security script to trigger on security status changes.
The middle part is strange as the security panel is, in fact, part of the devices and arming/disarming actually does trigger device scripts. However, it's true that checking the "globalvariables['Security']" variable does return the three status mentioned above (this time in their past form, "Arm
ed" or "Disarm
ed")
I have two scripts (one device, one security), each logging the values of both the "Security Panel" device and the "Security" variable. Here is the log when disarming/arming from the Security Panel:
Sun Feb 23 16:53:04 2014 LUA: Security script - otherdevices['Security Panel'] = 'Arm Home' and globalvariables['Security'] = 'Disarmed'
Sun Feb 23 16:53:04 2014 LUA: Device script - otherdevices['Security Panel'] = 'Normal' and globalvariables['Security'] = 'Disarmed'
Sun Feb 23 16:53:04 2014 (System) Domoticz Security Status (Security Panel)
Sun Feb 23 16:53:09 2014 LUA: Security script - otherdevices['Security Panel'] = 'Normal' and globalvariables['Security'] = 'Armed Home'
Sun Feb 23 16:53:09 2014 LUA: Device script - otherdevices['Security Panel'] = 'Arm Home' and globalvariables['Security'] = 'Armed Home'
Sun Feb 23 16:53:09 2014 (System) Domoticz Security Status (Security Panel)
Best regards,
Vicne
Posted: Sunday 23 February 2014 17:08
by Vicne
OK, anyway, here is my script to arm/disarm Domoticz's security from my X10 KeyChain remote:
for device, value in pairs(devicechanged) do
if (device == 'KeyChain') then
print ("Setting 'Security Panel' to '" .. otherdevices[device] .. "' state")
commandArray['Security Panel'] = otherdevices[device]
And here is the corresponding log with an Arm/Disarm cycle (delay = 0) :
Sun Feb 23 17:00:57 2014 LUA: Setting 'Security Panel' to 'Arm Away' state
Sun Feb 23 17:00:57 2014 Script event triggered: /volume1/misc/domoticz/scripts/lua/script_device_CheckSecurity.lua
Sun Feb 23 17:00:57 2014 (RfxTrx433) Security 1 (KeyChain)
Sun Feb 23 17:00:57 2014 (System) Domoticz Security Status (Security Panel)
Sun Feb 23 17:01:03 2014 LUA: Setting 'Security Panel' to 'Disarm' state
Sun Feb 23 17:01:03 2014 Script event triggered: /volume1/misc/domoticz/scripts/lua/script_device_CheckSecurity.lua
Sun Feb 23 17:01:03 2014 (RfxTrx433) Security 1 (KeyChain)
Sun Feb 23 17:01:03 2014 (System) Domoticz Security Status (Security Panel)
Seems to work pretty well. Hope it helps.
Best regards,
Vicne
Posted: Monday 24 February 2014 21:05
by Niekoesj
Hi Vicne,
Ah good investigation! I'll check the script later this evening.
I need to learn a bit more about the LUA scripting
Posted: Friday 22 April 2016 10:39
by pecora
I'm not get it work... This is the script I have
if (devicechanged['RemoteHJ'] == 'On') then
commandArray['Domoticz Security Panel'] = 'Arm Away'
What do I wrong
Posted: Saturday 18 June 2016 17:43
by daryah
This is a 2 year old discussion that was brought to life in April 2016 and I seem to be having an issue related to this as well. Will try to provide more info. though
I have created a dummy device switCh called "SystemARMnDISARM" as an on/off switch. I would like this to control the security panel state. The following is my code sample
if (devicechanged['SystemARMnDISARM'] == 'On') then
print('AlarmPanel Arm Away')
commandArray['Security Panel'] = 'Arm Away'
if (devicechanged['SystemARMnDISARM'] == 'Off') then
print('AlarmPanel Disarming')
commandArray['Security Panel'] = 'Disarm'
My log states the following when I try to toggle the switch.
2016-06-18 14:28:09.839 EventSystem: reset all events...
2016-06-18 14:28:33.165 User: Admin initiated a switch command
2016-06-18 14:28:33.172 LUA: AlarmPanel Arm Away
2016-06-18 14:28:33.166 (DummyHW) Lighting 1 (SystemARMnDISARM)
2016-06-18 14:29:00.022 Error: EventSystem: in System Arm and Disarm: [string "-- ..."]:26: attempt to index global 'devicechanged' (a nil value)
This error then continues to occur until I make the Event inactive.
Line 26 is the first line of the first if..then statement
Can anyone spot the missing trick?
Posted: Saturday 18 June 2016 17:52
by jvdz
Is this a script made with the internal Script Editor? If so, change the dropdown box below LUA from All to Device.
Jos
Posted: Sunday 19 June 2016 9:48
by daryah
wow - yes it was done in the script editor and making the change to Device has indeed removed the constant error. I would ask why this has worked but I would like to save your invaluable help for the next question.
If the security panel status has successfully changed state then should the actual security panel also show the changed state? Unfortunately it hasn't and a script I have currently running to turn on / off a device (which works when I activate using the actual panel) does not seem to run. This makes me feel the panel is not actually being activated / deactivated - My LUA skills are rudimentary so I would print the actual state of the panel in my lua code after the declaration - but afraid I don't know the command!
Posted: Sunday 19 June 2016 10:51
by jvdz
daryah wrote:wow - yes it was done in the script editor and making the change to Device has indeed removed the constant error. I would ask why this has worked but I would like to save your invaluable help for the next question.
It is quite simple ones you know it: All means that the script is shelled with each event, which means for Device, Time and Variable change events. Looking at the log records you posted it was pretty clear this was a time event and the DeviceChanged table isn't available in Time events.. hence the error.
To check the Security panel changes you simply should see an entry in the domoticz log, but could also write a script that is triggered when the security panel changes by selecting "Security" in the dropdownbox and then create your own print of its status.
print('### SecPanel: status changed to ' .. globalvariables['Security'])
Jos
Posted: Sunday 19 June 2016 20:45
by daryah
ok - i see why the error may have occured... devicechanged should only be used for device based events... but I trying to figure that out from the error response needs fluency in domoticz errors speak - which I unfortunately lack
updated the code to following:-
print('gonna attempt to arm away')
print('gonna attempt to disarm')
and getting following:-
2016-06-19 18:36:43.094 EventSystem: reset all events...
2016-06-19 18:36:50.663 User: Admin initiated a switch command
2016-06-19 18:36:50.669 LUA: gonna attempt to arm away
2016-06-19 18:36:50.670 LUA: ### SecPanel: status changed to Disarmed
2016-06-19 18:36:50.663 (DummyHW) Lighting 1 (SystemARMnDISARM)
2016-06-19 18:37:08.297 User: Admin initiated a switch command
2016-06-19 18:37:08.303 LUA: gonna attempt to disarm
2016-06-19 18:37:08.303 LUA: ### SecPanel: status changed to Disarmed
2016-06-19 18:37:08.298 (DummyHW) Lighting 1 (SystemARMnDISARM)
2016-06-19 18:37:38.547 User: Admin initiated a switch command
2016-06-19 18:37:38.554 LUA: gonna attempt to arm away
2016-06-19 18:37:38.554 LUA: ### SecPanel: status changed to Disarmed
So suspicion correct. The script is simply not affecting the security panel state. Am I using the right english tense? ie "Arm Away" vs Arming, Armed...
Posted: Sunday 19 June 2016 21:54
by jvdz
The SecPanel isn't set yet at the time you print its status, so do as I suggested and make it a separate script that is triggered on the Security event!
... oh and make the set security panel look like this:
commandArray['SecPanel']='Disarm'
commandArray['SecPanel']='Arm Away'
Jos
Posted: Monday 20 June 2016 9:33
by daryah
Hi - I changed the Lua code to say SecPanel and created another lua script to print the status based on a security event.
The print script does NOT get triggered when I press the dummy switch but does when I use the Security Panel directly. I have another blockly script already running that also gets triggered on security events, and this also only runs on panel arm / disarms.
The lua SecPanel sets continue to be ignored..
Posted: Monday 20 June 2016 16:25
by daryah
ok - managed to get it resolved - issue has been raised before here -
viewtopic.php?t=8031
I set the password for the security panel and then was able to see it under my devices. Created a switch "IntSecPanel" (could call it anything really) via the green arrow and can now see this switch. My LUA script works after swapping out switch names
If I was more curious and had more time to play around with domoticz e.g. rather then clash of clans, I would test to see if I could use Blockly set commands to flip IntSecPanel rather then Lua
When I switch IntSecPanel from Dashboard I get prompted for the Pin which I can enter using the Android Keyboard.
However, as my dedicated Android device already has a pattern lock to access it, the need for two factor security panel access seems overkill to me.. As such, will just stick to my dummy switch which bypasses the need for a pin.
Next stop perhaps, purchase the Domoticz App Premium license and utilize the NFC capabilities of my device to arm / disarm
Posted: Sunday 22 October 2017 12:06
by Stockfisch
trying to set up a simple Alarm System in my new Domoticz I found this Threat.
I'm trying exactly the same as above, but with no success. I don't manage to change the Security Panel status!
I have added a virtual switch to change from disarmed to arm away and vice versa.
if (devicechanged['HouseMode'] == 'On') then
if (devicechanged['HouseMode'] == 'Off') then
I have used the WebIf event editor and have set the trigger to "device".
Additionally I have added another script with trigger "security" as suggested above:
printlog('###', 'SecPanel: status changed to ' .. globalvariables['Security'])
this seems not be executed after the first script ran.
What am I doing wrong?
Thanks Dirk
Posted: Sunday 22 October 2017 12:30
by jvdz
Couple of questions:
- You do get the LOG entry from the print() statements in the first script?
- You do have a Switch device with the exact name "SecPanel" with the secpanel (Lock&Key) icon?
EDIT: You might want to update the second script to:
As the printlog() is a Function I use for my logging that might not be available for you.
Jos
Posted: Sunday 22 October 2017 12:55
by Stockfisch
OMG, I' feeling stupid!
My Security Panel is named "Domoticz Security Panel" in the dashboard!
Changing the name in the script did the trick!
Thanks a lot, Dirk
