Can someone please help explain why this script won't run in Domoticz?
All kinds of 'OS' scripts
leecollings
Post by leecollings »
I have a very simple script that runs perfectly fine from the pi user in a terminal window, but when I try to place the command into a bash script and fire it from an On Action in Domoticz, all I get is 'Executing script' in the log, and nothing happens.
/home/pi/domoticz/scripts/skyhd_pause.sh contains:
#!/bin/bash
sky-remote-cli 192.168.0.109 pause &
When I run
in an SSH window after logging in as user pi, the script runs fine and my Sky box pauses.
However, I've created a dummy switch and entered script://skyhd_pause.sh in the On Action, the log file says:
2017-05-25 20:23:37.996 Executing script: /home/pi/domoticz/scripts/skyhd_pause.sh
But nothing happens, no error nothing.
What am I doing wrong?
Re: Can someone please help explain why this script won't run in Domoticz?
Have you tried adding an extra forward / ?
like script:///
Egregius
Domoticz version: v2024.7
Post by Egregius »
If you add a third slash you must specify the full path:
script:///home/pi/domoticz/scripts/skyhd_pause.sh
Add a simple logline to your script, something like:
#!/bin/bash
NOW=$(date +"%Y-%m-%d")
LOGFILE=/home/pi/sky-remote.$NOW.log
echo  $(date +"%Y-%m-%d %H:%M:%S") sky-remote pause | tee -a $LOGFILE
That should create a logfile (every day a new file) and add the timestamp of execution to it.
Personnaly I would set the command as an option in the command line:
#!/bin/bash
COMMAND="$1"
echo  $(date +"%Y-%m-%d %H:%M:%S") sky-remote $COMMAND | tee -a $LOGFILE
sky-remote-cli 192.168.0.109 $COMMAND &
And then use this in domoticz:
script:///home/pi/domoticz/scripts/skyhd_pause.sh pause
That way you can use one script for other commands to, I assume you have other commands to sent as well?
leecollings
Okay, so I don't need a third slash, as my script is in the correct script folder. If the path to the script was incorrect, I wouldn't see
Executing script
in the log would I?
I don't necessarily want to change the script itself in terms of the command, as I only use the pause command, so this is fine for me.
It's more the case that I Want to find out why it works when I execute the command directly in the terminal, but nothing happens from DOmoticz.
leecollings
waaren wrote:Have you tried adding an extra forward / ?
like script:///
Since my script location is in the default script folder as recognised by Domoticz, I don't need to have three slashes.
The third slash would only indicate that I'm specifying a path starting from the root, which I am not.
emme
Domoticz version: latest
Post by emme »
can you list the rights of the file? (ls -l )
normally this should not be an issue.... but I have the same problem with a .sh script with I had to issue a
sudo chmod +X ircommand.sh
ciao
M
"We always done this way"
leecollings
Sure, currently showing as
-rwxr-xr-x
which seems to be the same as the standard
update_domoticz
script, and user/group is set to pi pi.
I do know, the permissions are set in FileZilla for this file as 0755, if that helps?
emme
Post by emme »
where the file sky-remote-cli is located?
try to enter its full path in the script
eg. if it is stored in /usr/bin
/usr/bin/sky-remote-cli 192.168.0.109 pause
ciao
M
Egregius
Post by Egregius »
Was the timestamp written in the logfile?
leecollings
emme wrote:where the file sky-remote-cli is located?
ciao
M
I've never had to do that before when it previously worked.
Besides I have no idea where the actual files are, I've never seen them.
Egregius
Post by Egregius »
With this you can find the location:
sudo find / -name "sky-remote-cli"
But why don't you add the logfile line? Then at least you know it the script is executed or not.
leecollings
2017-05-27 07:49:41.509 Executing script: /home/pi/domoticz/scripts/skyhd_pause.sh
Egregius
Post by Egregius »
That's the domoticz logfile, not the one created by the script.
leecollings
In which case you'll need to explain how I view this log file, because I've never heard of it, or ever seen it before.
leecollings
Hmm that seems a bit unnecessary as this has worked fine in the past without having to add anything extra to the script.
Could it just be a user/group permissions issue? Maybe I need to change ownership of the file so that Domoticz can execute it?
Egregius
Post by Egregius »
Asking for help but not accepting it?
Good luck with it.
leecollings
What I'm saying is, there must be something simple here, as this has worked fine before doing the exact same thing, but now it's not.
jvdz
Domoticz version: 4.107
Post by jvdz »
So help us to help yourself and add some debugging statements in the script to understand what is going on. ;-)
leecollings
Hey, so the log file that was created contains one line:
2017-05-29 17:56:02 sky-remote pause
Looks like the command is being executed then?
