heating scenario
markjgabb
Domoticz version: 3.8153
heating scenario
Post by markjgabb »
hi guys
i have the following blocky, but it never seems to activate....
current temp as i write this is 19
nothing in logs about fails...it just seems to never evaluate
current values from blocky check current values shows as below
35 Office Temp 19 2017-05-23 16:31:45 19
lounge temp control.PNG (16.9 KiB) Viewed 1966 times
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
Egregius
Domoticz version: v2024.7
Re: heating scenario
Post by Egregius »
If it's now 19° it can't do anything. It's not lower than 17 and not higher than 20, right?
ropske
Domoticz version: V3_8394
Post by ropske »
that's also what i see Egrerius :)
markjgabb
Post by markjgabb »
ah crap....yeah your right...i was reading it bacwards....i now feel really stupid thanks guys wow
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
markjgabb
Post by markjgabb »
ok heating scenario part 2....
anyone have any ideas how i would go about adding a scenario or perhaps another else if, so that if i turn my heating on remotely it will work..
as you can see ive got presence running with occupied so that when no one is home the heater turns off...
but i would like something so that if im half an hour from home and i know its cold i can turn it on before i get home
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
StanHD
Post by StanHD »
One way would be to add a virtual "Manual Override" or an "Auto" Switch
In your scenario you could add an "Override" switch that can work with the Occupied switch:-
If [Heating =On] And [Occupied = Off] And [Override = Off] Do Set [Heating = Off]
Then add the appropriate conditions to the first "Else If":-
Else If [Temp <= 17] And [Heating = Off] And [[Occupied = On] Or [Override = On]] Do Set [Heating = On]
(Note how the "Or" is "nested")
Below is a Blockley I use to successfully control a ceiling fan. Note where the "Auto" condition is required to be on to run the fan or turn it off. So I can switch this to regain manual control.
Python:- Broadlink RM2, Sonos
markjgabb
Post by markjgabb »
oh wow....ok quite complicated things are possible. thats quite impressive
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
