Sensor
Posted: Saturday 20 May 2017 8:08
by elgringo
I have created a script (via ping) to detect my LAN printer is on or off. I cannot enable/disable the printer so it is only a sensor.
Script send commands van JSON
pi@raspberrypi:~ $ curl "http://pi:[email protected]:8080/json.htm?type=command&param=switchlight&idx=10&switchcmd=On"
   "status" : "OK",
   "title" : "SwitchLight"
However in Domoticz I can toggle the 'sensor'. Which is not possible since it is a sensor not a switch. I found the option to protect it but than it is impossible to toggel it via JSON:
pi@raspberrypi:~ $ curl "http://pi:[email protected]:8080/json.htm?type=command&param=switchlight&idx=10&switchcmd=Off"
   "message" : "WRONG CODE",
   "status" : "ERROR",
How can I prevent Domoticz to toggle the sensor?
