Debug RFXCOM with RasPi ?
Posted: Wednesday 17 May 2017 23:07
Been using Domoticz along with RFXCOM for a while. I havent used it to transmit for a while (party due to other work) but its been recieving perfectly about 15 sensors and modules.
I tried last night to pair it to some HomeEasy light controllers. I have used both their HE200 and HE300 controllers. Domoticz see's the command perfectly although they end up getting decoded as the following:
Strangely the HE300 is seen as two devices
However when I use Domo to send the command nothing happens. As the light and plug controller are very near (1meter) i dont think there is an issue that way.
I do have some other devices that used to work and again these dont work (although may be out of range - not 100% sure)
How can I verify the RFXCOM is actually transmitting ? Is there a debug mode ?
I have flashed RFCCOM last night up to 1019 in case it was an issue....
Thanks anyone who may be able to assist.
HE200W
garage-cr-he200w Chime SelectPlus OnCode: Select all
garage-cr-he300-1 Lighting 2 AC
garage-cr-he300-2 Lighting 2 HomeEasy EUI do have some other devices that used to work and again these dont work (although may be out of range - not 100% sure)
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver
Version: Ext2/1019
