Send "Off" command twice in a row
sammyke007
Domoticz version: 2022.1
Post by sammyke007 »
Hi guys
I'm kind off new to Domoticz, but I'm already able to control all of my lights, Somfy shutters, make some Blocky scripts, ...
The one thing that won't work for now is activating my alarmsystem. I made an "Off" switch that's sending the right IR code, however I need to press the Off button twice in a row to get my alarm to listen to it.
I tried this:
function blinkLight(light, times)
   times = times or 2
   local pause = 0
   for i = 1, times do
      commandArray[#commandArray + 1]={[light]='On AFTER '..pause }
      pause = pause + 3
      commandArray[#commandArray + 1]={[light]='Off AFTER '..pause }
      pause = pause + 3
-- if (devicechanged['AlarmOff'] == 'Off') then
   blinkLight("AlarmOff") -- blink device 75 the default number of times (which is 2)
-- end
And it's working, however it's looping (I understand why...)
The second script I tried was
-- if (deviceName=='AlarmOff') then
if devicechanged['AlarmOff'] == 'Off' then
            commandArray['AlarmOff']='On'
            commandArray[1]={['AlarmOff']='Off'}
            commandArray[2]={['AlarmOff']='On'}
            commandArray[3]={['AlarmOff']='Off'}
            commandArray[4]={['AlarmOff']='On'}
That aint working either...
Do I need to use a variabel?
Anyone that can help me out please?
Kind regards!
Siewert308SW
Domoticz version: Stable
Re: Send "Off" command twice in a row
Post by Siewert308SW »
Why not using the following commandArray?
commandArray["Dummy"]='On AFTER 5 REPEAT 2 INTERVAL 10'
where:
AFTER = Switch device after 5 seconds
REPEAT = How many times the command has to be repeated
INTERVAL = When to start the new command when the first commandArray is finished.
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
sion
Post by sion »
It's probably neater using code as a above, you you could possibly add a group. And add you alarm switch twice. With a second off or on delay on the 2nd one
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
sammyke007
Siewert308SW wrote:Why not using the following commandArray?
where:
It's working!
I use
if devicechanged['AlarmOff'] == 'On' then
        commandArray["AlarmOff"]='Off REPEAT 2 INTERVAL 0.5'
Tnx a LOT!
