Can not discover MiLight?
Posted: Monday 15 May 2017 17:57
by olskar
I get this error when trying to pair my RGBW MiLIght?
2017-05-15 17:16:36.119 User: initiated a RFLink Device Create command: 10;MiLightv1;F746;01;34BC;PAIR;
2017-05-15 17:16:36.194 RFLink: 20;16;CMD UNKNOWN;
2017-05-15 17:16:36.194 Error: RFLink: Error/Unknown command received!...
Re: Can not discover MiLight?
Posted: Monday 15 May 2017 18:27
by tontze
whats you hardware setup ? have you enabled milight from rflink ?
Posted: Wednesday 31 May 2017 16:25
by Treve
I have the same problem "RFLink: Error/Unknown command received!..."
I'm using RFLink soft v46 on a Mega 2560 board direct (wire) connected with a NRF24L01 on a Raspberry with Domoticz v3.5877
NRF24L01 is connected with a socketadapter to 5 volt powersource from the Mega 5v/gnd.
the Domoticz logfile shows 'RFLink Detected, Version: 1.1 Revision: 46 Build: 0'
Adding a device in Domoticz works quit well, adding a switch works also well with commands;
1. 10;MiLightv1;F746;01;34BC;PAIR;
2. 20;17;MiLightv1;ID=F746;SWITCH=01;RGBW=8690;CMD=ON;
But when i activate the switch, message 'RFLink: Error/Unknown command received!' occur in the logfile from Domoticz.
When i press the on or off button of the new created switch the rx/tx leds are blinking on the Mega board.
My wifibridge v4 and 4 RGBWW bulbs are working good in Domoticz, but i want to controll more individual RGBWW bulbs then 4.
