Plugins not showing in hardware list
Posted: Friday 12 May 2017 16:08
Hallo.
I've been searching for some days an answer to my problem but I'm afraid I'm missing something and don't know what.
I'm running Domoticz 3.7449 on a Linux Ubuntu 14.04 system. It's a fresh install (I've installed from the beginning one week ago because I couldn't find a way to sort the problem out, but without luck)
It's working fine but NO PLUGINS are loaded, even in the startup log I can't see an attempt to load python plugins...
2017-05-12 14:21:13.212 Domoticz V3.7449 (c)2012-2017 GizMoCuz
2017-05-12 14:21:13.212 Build Hash: 9df6061, Date: 2017-05-08 18:36:04
2017-05-12 14:21:13.213 Startup Path: /home/domobianchi/domoticz/
2017-05-12 14:21:13.357 Sunrise: 05:58:00 SunSet:20:44:00
2017-05-12 14:21:13.357 EventSystem: reset all events...
2017-05-12 14:21:13.380 Active notification Subsystems: gcm (1/12)
2017-05-12 14:21:15.974 WebServer(HTTP) started on address: :: with port 5001
2017-05-12 14:21:16.289 Incoming connection from: 192.168.1.200
2017-05-12 14:21:25.659 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Address already in use
2017-05-12 14:21:25.659 Error: WebServer(SSL) check privileges for opening ports below 1024
2017-05-12 14:21:25.659 Proxymanager started.
2017-05-12 14:21:28.878 Starting shared server on: :::6144
2017-05-12 14:21:28.879 TCPServer: shared server started...
2017-05-12 14:21:28.880 RxQueue: queue worker started...
2017-05-12 14:21:30.881 EventSystem: reset all events...
2017-05-12 14:21:30.882 EventSystem: reset all device statuses...
2017-05-12 14:21:30.884 EventSystem: Started
2017-05-12 14:21:31.381 OpenZWave: using config in: /home/domobianchi/domoticz/Config/
2017-05-12 14:21:31.444 OpenZWave: Starting...
2017-05-12 14:21:31.444 OpenZWave: Version: 1.4-2518-gf95fa41-dirty
2017-05-12 14:21:31.582 OpenZWave: Driver Ready
2017-05-12 14:21:31.583 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-05-12 14:21:31.584 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2017-05-12 14:21:31.584 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2017-05-12 14:21:31.584 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.585 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2017-05-12 14:21:31.586 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.587 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.588 OpenZWave: Value_Added: Node: 12 (0x0c), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.589 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.590 OpenZWave: Value_Added: Node: 16 (0x10), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.590 OpenZWave: Value_Added: Node: 16 (0x10), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2017-05-12 14:21:31.592 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.592 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2017-05-12 14:21:31.594 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:22:08.954 OpenZWave: Received Node Dead notification from HomeID: 25288, NodeID: 7 (0x07)
2017-05-12 14:22:08.954 (Z-Wave) Light/Switch (Switch)
2017-05-12 14:22:13.830 OpenZWave: Received Node Dead notification from HomeID: 25288, NodeID: 10 (0x0a)
2017-05-12 14:22:13.829 (Z-Wave) Light/Switch (SwitchUnassigned)
2017-05-12 14:22:16.127 (Z-Wave) Light/Switch (Artemide)
2017-05-12 14:22:31.247 OpenZWave: Received timeout notification from HomeID: 25288, NodeID: 18 (0x12)
2017-05-12 14:22:31.572 OpenZWave: Awake Nodes queried
Python is this:
domobianchi@domobianchi-server:~/domoticz/plugins$ python --version
Python 3.4.3
I have some default stuff in plugins directory plus the Broadlink one that I've added
domobianchi@domobianchi-server:~/domoticz/plugins$ ls -ltr
totale 12
drwxr-xr-x 3 domobianchi domobianchi 4096 mag 8 21:17 AwoxSMP
drwxr-xr-x 2 domobianchi domobianchi 4096 mag 8 21:17 examples
drwxr-xr-x 2 domobianchi domobianchi 4096 mag 9 12:01 BroadlinkRM2
domobianchi@domobianchi-server:~/domoticz/plugins$ ls -ltr BroadlinkRM2/
totale 44
-rwxr-xr-x 1 domobianchi domobianchi 1473 mar 27 15:59 plugin_send.py
-rwxr-xr-x 1 domobianchi domobianchi 11422 apr 22 09:36 plugin_http.py
-rwxr-xr-x 1 domobianchi domobianchi 72 apr 22 09:36 plugin_http.sh
-rwxr-xr-x 1 domobianchi domobianchi 23475 apr 23 18:58 plugin.py
Unfortunately the plugins (I'm looking for broadlink RM) is not showing up in hardware list.
Please can you help me with this?
Thanks in advance!
Python is this:
Python 3.4.3
totale 12
totale 44
Thanks in advance!
