Xiaomi Humidifier
ben53252642
Xiaomi Humidifier
Post by ben53252642 »
The Xiaomi Humidifier now works with Domoticz for Linux (Ubuntu, Debian Raspberry Pi). Below is the setup, requires moderate Linux knowledge.
1) Requirements: apt-get install npm sudo screen jq
2) Install miIO Device Library: npm install --save miio
3) Install miio command line utility: npm install -g miio
4) Run this command to discover and sync the key from your Humidifier: miio --discover --sync
humidifier.js
#!/usr/bin/node
/* eslint-disable */
// Location of miio node lib
const miio = require('miio');
// No need to change any lines in this section
var deviceip = process.argv[2];
var secondarg = process.argv[3];
var thirdarg = process.argv[4];
function exit() {
process.exit(-1);
// Power On (on / off specified as on or off)
if ( secondarg === "power" ) {
        setTimeout(exit, 7000);
        miio.device({
        address: deviceip
}).then(device => {
                return device.call('set_power', [thirdarg])
                .then(console.log)
                .catch(console.error);
// Status
if ( secondarg === "status" ) {
        miio.device({
        address: deviceip
}).then(device => {
                return device.call('get_prop', ["humidity","temp_dec","power","mode","led_b","buzzer","child_lock","limit_hum","trans_level"])
                .then(console.log)
// Status temperature and humidity only
if ( secondarg === "status2" ) {
        miio.device({
        address: deviceip
}).then(device => {
                return device.call('get_prop', ["temp_dec","humidity"])
                .then(console.log)
// Set mode (silent, medium or high)
if ( secondarg === "mode" ) {
        miio.device({
        address: deviceip
}).then(device => {
                return device.call('set_mode', [thirdarg])
                .then(console.log)
// Set buzzer (on or off)
if ( secondarg === "buzzer" ) {
        miio.device({
        address: deviceip
}).then(device => {
                return device.call('set_buzzer', [thirdarg])
                .then(console.log)
// led
if ( secondarg === "led" ) {
        miio.device({
        address: deviceip
}).then(device => {
                return device.call('set_led_b', [JSON.parse(thirdarg)])
                .then(console.log)
// Humidity limit percent (specified as 40, 50, 60, 70 or 80)
if ( secondarg === "humiditylimit" ) {
        miio.device({
        address: deviceip
}).then(device => {
                return device.call('set_limit_hum', [JSON.parse(thirdarg)])
                .then(console.log)
Example use:
node humidifier.js 192.168.0.95 power off
node humidifier.js 192.168.0.95 status
node humidifier.js 192.168.0.95 status2
node humidifier.js 192.168.0.95 mode medium
node humidifier.js 192.168.0.95 buzzer off
node humidifier.js 192.168.0.95 led 2
node humidifier.js 192.168.0.95 humiditylimit 50
domoticzupdate.sh
#!/bin/bash
cd /root/xiaomi/humidifier
while true; do
# Main Bedroom Humidifier
# Get the data
data=$(node humidifier.js 192.168.0.95 status2)
# Sort it
temperature=$(echo "$data" | jq '.[0]' | sed 's/.\{2\}/&./g')
humidity=$(echo "$data" | jq '.[1]')
# Load it into Domoticz
curl -s "http://USERNAME:[email protected]/json.htm?type=command&param=udevice&idx=617&nvalue=0&svalue=${temperature};${humidity};0"
sleep 60
done
humidifiercontrol.sh
#!/bin/bash
if [ “$2” == “on” ]; then
node humidifier.js $1 buzzer off
node humidifier.js $1 mode $3
node humidifier.js $1 power on
node humidifier.js $1 led 2
fi
if [ “$2” == “off” ]; then
node humidifier.js $1 power off
fi
startup.sh
# Start humidifiermonitor
/usr/bin/screen -S humidifiermonitor -d -m /root/xiaomi/humidifier/domoticzupdate.sh
Lua Domoticz event control script:
commnadArray = {}
-- Main B Humidifier
if devicechanged['Main B Humidifier'] == 'Silent' then
    os.execute ('sudo screen -S humidifiertemp -d -m bash /root/xiaomi/humidifier/humidifiercontrol.sh 192.168.0.95 on silent')
if devicechanged['Main B Humidifier'] == 'Medium' then
    os.execute ('sudo screen -S humidifiertemp -d -m bash /root/xiaomi/humidifier/humidifiercontrol.sh 192.168.0.95 on medium')
if devicechanged['Main B Humidifier'] == 'High' then
    os.execute ('sudo screen -S humidifiertemp -d -m bash /root/xiaomi/humidifier/humidifiercontrol.sh 192.168.0.95 on high')
if devicechanged['Main B Humidifier'] == 'Off' then
    os.execute ('sudo screen -S humidifiertemp -d -m bash /root/xiaomi/humidifier/humidifiercontrol.sh 192.168.0.95 off')
Screenshots:
Screen Shot 2017-05-10 at 7.57.53 pm.png (92.43 KiB) Viewed 9730 times
Screen Shot 2017-05-10 at 7.59.07 pm.png (92.16 KiB) Viewed 9730 times
Screen Shot 2017-05-10 at 8.03.13 pm.png (368.6 KiB) Viewed 9725 times
deennoo
Re: Xiaomi Humidifier
Post by deennoo »
Great ! Same source for all other wifi device !
http://domo-attitude.fr
SimyriK
Domoticz version: 3.8153
Post by SimyriK »
Hi. A lot of messages like "Error: EventSystem: Lua script /home/user/domoticz/scripts/lua/script_device_BedroomHumidifier.lua did not return a commandArray". Does anyone know how to solve?
bigmak
Domoticz version: 4.10693
Post by bigmak »
SimyriK wrote: Friday 25 August 2017 6:29 Hi. A lot of messages like "Error: EventSystem: Lua script /home/user/domoticz/scripts/lua/script_device_BedroomHumidifier.lua did not return a commandArray". Does anyone know how to solve?
I have the same error.
Did you solve this problem?
bigmak
Post by bigmak »
Maybe it will help to someone like me.
I did step-by-step p.1-4.
Create humidifier.js with code shown above by path "/home/pi/Xiaomi"
After that you can try make commands and check that your Xiaomi Humidifier working from command line:
Then you need to know full path to "node".
Print in command line
pi@raspberrypi ~ $ which node
/home/pi/.nvm/versions/node/v6.0.0/bin/node
Save this path to notepad.
Then I created 4 files in /home/pi/Xiaomi:
humidifier_power_off.sh
#!/bin/sh
# Humidifier
# Set Power off
sudo /home/pi/.nvm/versions/node/v6.0.0/bin/node /home/pi/Xiaomi/humidifier.js 192.168.0.95 power off /dev/null
exit 0
humidifier_level_1.sh
#!/bin/sh
# Humidifier
# Set Silent mode
sudo /home/pi/.nvm/versions/node/v6.0.0/bin/node /home/pi/Xiaomi/humidifier.js 192.168.0.95 mode silent /dev/null
exit 0
humidifier_level_2.sh
#!/bin/sh
# Humidifier
# Set Medium mode
sudo /home/pi/.nvm/versions/node/v6.0.0/bin/node /home/pi/Xiaomi/humidifier.js 192.168.0.95 mode medium /dev/null
exit 0
humidifier_level_3.sh
#!/bin/sh
# Humidifier
# Set High mode
sudo /home/pi/.nvm/versions/node/v6.0.0/bin/node /home/pi/Xiaomi/humidifier.js 192.168.0.95 mode high /dev/null
exit 0
Make "chmod +x" for each file, for example:
$ chmod +x humidifier_level_3.sh
Let's go to Domoticz 3.8390, Menu->Setup->Hardware
Add Dummy virtual switch with name Humidifier
On this page press "Create virtual Sensors" and choose "Selector Switch" type.
Go to "Switches" and find your "Humidifier".
Press "Edit" button and rename Selector Levels - Off, Silent, Medium, High (or whatever you want).
In selector actions print path to your scripts with tripple slash, like this:
Off - script:///home/pi/Xiaomi/humidifier_power_off.sh
Silent - script:///home/pi/Xiaomi/humidifier_level_1.sh
Medium - script:///home/pi/Xiaomi/humidifier_level_2.sh
High - script:///home/pi/Xiaomi/humidifier_level_3.sh
That's it.
PS. It looks not very attractive, but it works! I am not programmer and if someone find better way - please write it!
bigmak
Post by bigmak »
One more update!
I checked code and now it works from Events (LUA).
1. My variant of humidifiercontrol.sh
I placed it on /home/pi/domoticz/scripts/humidifiercontrol.sh
#!/bin/bash
/home/pi/.nvm/versions/node/v6.0.0/bin/node /home/pi/Xiaomi/humidifier.js $1 mode $3
/home/pi/.nvm/versions/node/v6.0.0/bin/node /home/pi/Xiaomi/humidifier.js $1 power on
fi
/home/pi/.nvm/versions/node/v6.0.0/bin/node /home/pi/Xiaomi/humidifier.js $1 power off
fi
2. Domoticz->Menu->More Options->Events
Insert code:
-- Humidifier - this is the name of your dummy selector
if devicechanged['Humidifier'] == 'Silent' then
    os.execute ('sudo screen -S humidifiertemp -d -m /bin/bash /home/pi/domoticz/scripts/humidifiercontrol.sh 192.168.0.95 on silent')
if devicechanged['Humidifier'] == 'Medium' then
    os.execute ('sudo screen -S humidifiertemp -d -m /bin/bash /home/pi/domoticz/scripts/humidifiercontrol.sh 192.168.0.95 on medium')
if devicechanged['Humidifier'] == 'High' then
    os.execute ('sudo screen -S humidifiertemp -d -m /bin/bash /home/pi/domoticz/scripts/humidifiercontrol.sh 192.168.0.95 on high')
if devicechanged['Humidifier'] == 'Off' then
    os.execute ('sudo screen -S humidifiertemp -d -m /bin/bash /home/pi/domoticz/scripts/humidifiercontrol.sh 192.168.0.95 off /dev/null')
3. Don't forget change "All" to "Device" on the right upper corner of internal editor.
4. Name this event and save.
That's it! Now it works through LUA Event.
bigmak
Post by bigmak »
Corrective in domoticzupdate.sh.
Need to add port in command.
#!/bin/bash
while true; do
# Get the data
# Sort it
curl -s "http://USERNAME:[email protected]:PORT/json.htm?type=command&param=udevice&idx=617&nvalue=0&svalue=${temperature};${humidity};0"
sleep 60
done
DAVIZINHO
Post by DAVIZINHO »
Great job!!!
Its posible that the humidifier send a notification via domoticz when the water is empty??
DAVIZINHO
Post by DAVIZINHO »
hello,
someone can configure with this method the new xiaomi humidifier (smartmi with cube form)
thanks
mgrom
Post by mgrom »
I've modified python plugin for Xiaomi Air Purifier, and created plugin for Xiaomi Air Humidifier:
https://github.com/mgrom/domoticz-AirHumidifier
Have fun!
DAVIZINHO
Post by DAVIZINHO »
hello
This plugins are compatible with the 2 models of xiaomi humidifier (smartmi)?? or only with the first (round form, not cube)
thanks
molnaratti
Post by molnaratti »
mgrom wrote: Tuesday 12 June 2018 9:03 I've modified python plugin for Xiaomi Air Purifier, and created plugin for Xiaomi Air Humidifier:
Have fun!
What could be the problem?
pi@raspberrypi:~/domoticz/plugins/domoticz-AirHumidifier $ ./MyHumidify.py 192.168.1.191 581386dbf6457cdf84aef497e6a167fd --debug
Namespace(IPaddress='192.168.1.191', debug=True, mode=None, power=None, targetLevel=None, token='581386dbf6457cdf84aef497e6a167fd')
  File "./MyHumidify.py", line 59, in <module>
    print(MyHumidifier.status())
  File "/usr/local/lib/python3.5/dist-packages/miio/airhumidifier.py", line 254, in status
    properties
  File "/usr/local/lib/python3.5/dist-packages/miio/device.py", line 270, in send
    raise DeviceError(m.data.value["error"])
miio.exceptions.DeviceError: {'message': 'UART timeout', 'code': -9999}
Stimpy68
Post by Stimpy68 »
Any way to incorporate the water level in the tank? (depth attribute)
molnaratti
Stimpy68 wrote: Sunday 02 December 2018 12:44 Any way to incorporate the water level in the tank? (depth attribute)
/usr/local/bin/miiocli airhumidifierca1 --ip --token status
Power: on
Mode: OperationMode.Auto
Temperature: 20.2 °C
Humidity: 47 %
LED brightness: LedBrightness.Dim
Buzzer: False
Child lock: False
Target humidity: 70 %
Trans level: None
Speed: 824
Depth: 77
Dry: False
Use time: -2147483384
Hardware version: 0001
Button pressed: None
Stimpy68
Post by Stimpy68 »
molnaratti wrote: Tuesday 11 December 2018 19:24
Power: on
Humidity: 47 %
Buzzer: False
Child lock: False
Trans level: None
Speed: 824
Depth: 77
Dry: False
Thanks, but how do I get that visible in Domoticz?
ElPhilou
Post by ElPhilou »
Stimpy68 wrote: Monday 17 December 2018 18:01
Power: on
Humidity: 47 %
Buzzer: False
Child lock: False
Trans level: None
Speed: 824
Depth: 77
Dry: False
Sure, the water level is important, notification, etc...
You can add more informations in humidifier.js in status section, for exmple:
// Status
        miio.device({
        address: deviceip
}).then(device => {
                return device.call('get_prop', ["power", "mode", "temp_dec", "humidity", "buzzer", "led_b", "limit_hum", "trans_level", "depth", "dry" ])
                .then(console.log)
All I found : 'power', 'mode', 'temp_dec', 'humidity', 'buzzer', 'led_b', 'child_lock', 'limit_hum', 'trans_level', 'speed', 'depth', 'dry', 'use_time', 'button_pressed', 'hw_version'
If you find more, you are welcome :mrgreen:
Some don't work, like trans_level, always NUL and I don't know that is it... :roll:
After you can try to extract variables, like in, domoticzupdate.sh ;)
Something is strange, because with this script, for example now , depth give me 87, and MiHome give me 72% of Water Level :|
ElPhilou
Post by ElPhilou »
ElPhilou wrote: Saturday 16 February 2019 13:12
Found :) in fact the reference level is based on 120, so to have in percent you must divide by 1.2
Example : 87/1.2 = 72.5
so rnd = 72 % 8-)
Grinders
Post by Grinders »
ElPhilou wrote: Saturday 16 February 2019 13:12 Something is strange, because with this script, for example now , depth give me 87, and MiHome give me 72% of Water Level :|
I apologize for the stupid question, but I have no where information about the water level. Where can I see this in MIHOME?
ElPhilou
Post by ElPhilou »
Click on the device and you can see remaining water :D
Grinders
Post by Grinders »
ElPhilou wrote: Thursday 21 March 2019 16:35 Click on the device and you can see remaining water :D
Unfortunately, there is no data on how full the humidifier is.
IMG_7952.pdf
(286.88 KiB) Downloaded 136 times
IMG_7951.pdf
(232.59 KiB) Downloaded 97 times
