Help script problem!
liveviva
Post by liveviva »
I am a novice, and my English is very poor, please do not laugh at!
Well, I created a text device in domoticz, is used to obtain a number coming from ESPEasy, I hope to achieve with the script in domoticz, judging whether the number change, according to the number of executive action.
But when I use devicechanged, but found that the number has not changed the situation, he still repeated action...
I don't know where the problem is.
Here is the code:
-- loop through all the devices
for deviceName,deviceValue in pairs(devicechanged) do
if (devicechanged['Voice_Data']) then
    if (deviceValue == '1') then
        print('1')
    elseif (deviceValue == '2') then
        print('2')
mjdb
Domoticz version: all beta
Re: Help script problem!
Post by mjdb »
A suggestion, not tested. Try to read the current value as text:
CurrentText = tostring(otherdevices_svalues['Voice_Data'])
if (CurrentText == '1') then
etc.
2 x Domoticz on Raspberry Pi; 2 x RFXtrx433; Aeotec Z-Stick
KlikAanKlikUit ICS-2000 as Relay
Aeotec MultiSensors 6; Danfoss Z Thermostats 014G0013; Kaku Switches, Z-wave Switches
liveviva
Post by liveviva »
mjdb wrote:A suggestion, not tested. Try to read the current value as text:
etc.
The same problem.
When value = 1 repeat execution
When value = 2 to do Nothing...
Looks like devicechanged is not working!
jvdz
Domoticz version: 4.107
Post by jvdz »
Check the exact content of the variable you are testing with to see why things don't work as expected:
     print("|"..CurrentText .."|")
Jos
