Fireangel wht-630 / wst-630
assenzuid
Post by assenzuid »
I have a few Fireangel Smoke and Heat detectors (the are connected with each other for alarming), but is it possible to connected them to Domoticz?
I saw that Fireangel has an Z-Wave module, but these are for the HT and ST series and not for the WHT or WST series what i read.
I did some Google searches, but I can't find at which protocol the WHT and SHT are connecting with each other.
assenzuid
Re: Fireangel wht-630 / wst-630
Post by assenzuid »
I have bought a Fireangel Zwave module, device is recognized as Sprue Safety Products Unknown: type=0001, id=0001+
No devices are detected at the moment, is it possible that domoticz will support this device.
If more info is required or something, I will help where i can.
nlfva1
Post by nlfva1 »
I've bought a FireAngel smoke detector (SM-F-1EU) as well, inlcuding zwave module with aeotec zwave plus stick. Although the node shows unknow in the zwave gateway, 5 devices are created.
Device 249 in this list is turned on in case of fire or even with a test alarm. Device 250 turns on when the device is removed from the base plate. Device 252 will report a code, depending on the situation as described in link below, but have not tested this. To be continued. Anyway. With the current version of domoticz (2020.2) and openzwave it's possible to connect the fireangel zwave module to Domoticz.
https://www.fireangel.co.uk/hubfs/FireA ... k_2017.pdf
jompie
Domoticz version: 3.5877
Post by jompie »
although the last post on this topic is already some time ago, I have a question:
I have also Fireangel wst-630 with ZWAVE module. I see 4 devices in domoticz: 3 switches and 1 Alarm. In Domoticz the smoke alarm is put to ON when I press the Test button on the module. Also when there is realy smoke detected the smoke alarm in Domoticz is put to ON. So from that point of view I can't see whether it is a test alarm or a real alarm. However, luckily in the log of domoticz, a message is shown on my AEOTEC Zwave stick, that it concerned a test (in the first case) and a real smoke alarm in the second case.
My question, can I somehow extract this information? I searched a lot of different forums, goolge etc...but couldn't find an answer.
I would like to build a script that notifies me in case of a specific alarm (test/real/tamper...) and not a general notification based on the status ON.
Domoticz Log Zwave.jpg (74.79 KiB) Viewed 979 times
Domoticz Log Zwave1.jpg (73.6 KiB) Viewed 979 times
KAKU switches/receivers/Motion sensor/Doorbell
Oregon Temp sensors, TFA Temp sensor
Mertik controller
Raspberry Pi, RFXCom
