Scene / Group as trigger Topic is solved
poudenes
Domoticz version: 3.8993
Post by poudenes »
I didn't find it here, so ask for it.
Can i use Scene or Group as trigger? like:
When > sunset and < sunrise and group "daytime" = on then group "eventing" to on
In blocky you can't use scene or group as a value trigger. But can you do it in LUA?
Thanks Peter
poudenes
Re: Scene / Group as trigger
Post by poudenes »
Tried this but test variable won't change.
The group Movie show "Mixed" when its on and also try it in script =='Mixed" but also not working.
Maybe i do something wrong
if devicechanged ['Group:Movie'] == 'On'
    commandArray['Variable:Morning'] = '5'
if devicechanged ['Group:Movie'] == 'Off' then
    commandArray['Variable:Morning'] = '3'
zicht
Domoticz version: 2023.1+
Post by zicht »
poudenes wrote:Hi all,
Thanks Peter
This MIXED means that in your group some switches are on and some are Off.
So there is no real ON or OFF position in that case.
As soon as all in the group are on or all in the group are off the status will change from mixed to on or off
I propose a work around as i do not know the status right away to check against.
if devicechanged ['Group:Movie'] == 'On' then commandArray['Variable:Morning'] = '5' end
if devicechanged ['Group:Movie'] ~= 'On' and devicechanged ['Group:Movie'] ~= 'Off' then commandArray['Variable:Morning'] = '4' end
if devicechanged ['Group:Movie'] == 'Off' then commandArray['Variable:Morning'] = '3' end
You could do a print(otherdevices ['Group:Movie']) to see in the log what the actual status is to check against :) but the above should work
