Sending raw live data somewhere else
Posted: Saturday 06 May 2017 14:19
by kasei
So I get temperature and humidity readings thanks to an RFLink connected to my raspberry pi.
Domoticz is set to read data from the rflink.
I'd like to send temperature and humidity values to another website as they come (via POST or GET)
any idea ?
thanks in advance !
Re: Sending raw live data somewhere else
Posted: Saturday 06 May 2017 15:40
by jvdz
Should be fairly simple when you use for example lua.
You simply make a device script which tests for the devicechanged() containing the information and do an OpenUrl command.
Something like this: (untested)
if devicechanged("Temp") then
	tempval =  otherdevices_svalues['Temp']
	commandArray['OpenURL']='website/url?temp=' .. tostring(tempval)
EndFunc
Jos
Posted: Saturday 06 May 2017 16:20
by asjmcguire
jvdz wrote:Should be fairly simple when you use for example lua.
EndFunc
Jos
Shouldn't this devicechanged test be using:
devicechanged['Temp_Temperature'] ?
Posted: Saturday 06 May 2017 20:37
by Lebo2d9
With mqtt?
Verstuurd vanaf mijn SM-G920F met Tapatalk
