Hi, i've installed multiple double switch but this is the last one for complete my light automation and it's over the template in the manual.
I've a relay that control my entrance light, with 3 buttons around the room for turn on the light from every way someone is coming.
How can i connect to this relay one port of the fgs-223? (the other port will goes to one normal switch so no problem...)
Thanks in advance for any help!
Fibaro FGS-223 and relay
YcKe
Re: Fibaro FGS-223 and relay
Hi TheCondor,
You should look for the switch which is directly connected to the light bulb. Unplug that wire connected to the light and integrate your relay in between. This way your existing switch system will remain only now your relay will be the master switch.
Greetz YcKe
Greetz YcKe
