RTS pulse width
Posted: Tuesday 02 May 2017 10:28
by mrefex
Is it possible to make the ON/OFF/STOP command shorter ?
I have some blinds with a tilt function and with domoticz it is not possible to put the blinds up or down.
This is because the ON or OFF command is to long while transmitting. thereby the blinds are tilting instead of going to the open or close position
Re: RTS pulse width
Posted: Tuesday 02 May 2017 10:39
by emme
how you control them? (hardware)
I have fibato motor control that support UP/DOWN/STOP and the switch is configured as BLINDS with PERCENTAGE
then in the device config I can set up timers for lamellas and positioning
Re: RTS pulse width
Posted: Tuesday 02 May 2017 10:46
by mrefex
RFLINK R46 ..i will try the percentage mode (never tried that)
Re: RTS pulse width
Posted: Tuesday 02 May 2017 10:49
by emme
uh... sorry
did not consider the area and post title
Re: RTS pulse width
Posted: Tuesday 02 May 2017 11:02
by mrefex
the percentage mode doesn't work..also i miss the STOP button which refers to the MY psoition of the blinds..i think it's a programming code in the RFLINK software on the adruino.
Re: RTS pulse width
Posted: Tuesday 02 May 2017 13:10
by Stuntteam
We will look for a fix.. check pm
Re: RTS pulse width
Posted: Sunday 21 May 2017 14:52
by morilm
Hi all.
Any update on this? I have just installed a new blinds at home and the regular on/off only move the blinds a bit. This the one allowing the orientation.
Other sonfy blinds I have (normal blinds) works perfectly so this seems to be a new kind of protocol.
I'll be doing some logging and I'll send it to the rflink team to see if they can implemented it
Re: RTS pulse width
Posted: Monday 22 April 2019 11:50
by whitecube
mrefex wrote: Tuesday 02 May 2017 10:28
i have exact the opposite problem
with rflink r48 the command is to short. it moves a bit (little orientation) and stops. i need the command longer
