Python dimmer/ light script for use in scene
Posted: Thursday 27 April 2017 1:36
Hi guys!
New to this forum as a user but have been coming back to this website as a reader the last week or so. Lots of useful information here so I thought I'd share a little script I made.
I made the script for use in my 'Home' preset that sets my thermostat to 21 degrees and turns a (dimmed) light on but only when after sundown and before sunrise. It's but a small thing but I thought I'd share, lemme know what you think!
#!/usr/bin/python
import sys
import requests
import datetime
# Settings for the domoticz server, change these before running
domoticzserver= "ip_address:port"
domoticzusername = "user"
domoticzpassword = "pass"
switchid = "idx"
# in case you want to control a dimmer light like I do
domoticzurl = 'http://'+domoticzserver+'/json.htm?type=command¶m=switchlight&idx=' + switchid + '&switchcmd=Set%20Level&level=100'
# in case you simply want to turn on a light (uncomment this one by removing the # sign and place one in front of the line above)
#domoticzurl = 'http://'+domoticzserver+'/json.htm?type=command¶m=switchlight&idx=99&switchcmd=Off
# DO NOT CHANGE BEYOND THIS LINE (unless you want to do something else ;)
now = datetime.datetime.now().strftime('%H:%M')
sunsetUrl = 'http://'+domoticzserver+'/json.htm?type=command¶m=getSunRiseSet'
# Function that returns current sunset and sunrise times from Domoticz
def get_sunriseset():
r = requests.get(sunsetUrl, auth=(domoticzusername, domoticzpassword))
json_object = r.json()
if json_object["status"] == "OK":
sunset = json_object["Sunset"]
sunset = datetime.datetime.strptime(sunset, '%H:%M')
sunset = datetime.datetime.strftime(sunset, '%H:%M')
sunrise = json_object["Sunrise"]
sunrise = datetime.datetime.strptime(sunrise, '%H:%M')
sunrise = datetime.datetime.strftime(sunrise, '%H:%M')
else:
print(json_object)
print("Something went wrong in the json call")
sys.exit(0)
return sunset, sunrise
sunriseset = get_sunriseset()
sunset = sunriseset[0]
sunrise = sunriseset[1]
if now < sunset and sunrise > now or now > sunset:
print("Still too dark to go without lights!")
requests.put(domoticzurl, auth=(domoticzusername, domoticzpassword))
else:
print(now + " - " + sunset + " - " + sunrise)
print("It's not dark outside so doing nothing")
sys.exit(0)
