Hi G3rard,
Here you go.
Note that several extra libraries are needed.
I used luarocks to get them for Lua and pip
3 for Python
3.
Lua-
function SendToPython(device, data)
--print("Start")
if not JSON then
JSON = require "cjson"
if device and data then
d = {}
d[device] = data
changed = JSON.encode(d)
elseif devicechanged then
changed = JSON.encode(devicechanged)
changed = ""
devices = JSON.encode(otherdevices)
idx = JSON.encode(otherdevices_idx)
lastupdate = JSON.encode(otherdevices_lastupdate)
data = changed..'|'..devices..'|'..idx..'|'..lastupdate
package.loadlib("core.so", "*")
local Socket = require "socket"
local tcp = Socket.connect('127.0.0.1', 8088)
if not tcp then
print("Python socket connect failed")
return
tcp:settimeout(2)
i, status = tcp:send(data);
if not i then
print("Python send failed - "..status)
tcp:close()
--print("End")
This is all my Python
3 code, with functions to schedule the tasks of:
Deleting old unused devices,
Checking battery levels,
Checking if certain local network devices are really online, and
Running internet speed check.
#!/usr/local/bin/python3
import socket
import sys
import os
import json
import urllib
import threading
import signal
import time
import requests
import sched
import re
import speedtest
from datetime import datetime
from apscheduler.schedulers.background import BackgroundScheduler
from urllib.request import urlopen
scheduler = BackgroundScheduler()
HOST = '' # Symbolic name meaning all available interfaces
PORT = 8088 # Arbitrary non-privileged port
URL_DOMOTICZ = 'http://localhost:8080/json.htm?type='
f_log = open('/home/pi/domoticz/domoticz-helper.log','w')
def DTstr():
return datetime.now().strftime('%Y-%m-%d %H:%M:%S.%f')[:-3]
def Log(msg):
msg = DTstr() + " " + msg
print(msg)
print(msg, file=f_log, flush=True)
#Bind socket to local host and port
try:
skt = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
skt.bind((HOST, PORT))
#Start listening on socket
skt.listen(5)
Log('Socket now listening')
except OSError as msg:
print('Bind failed. Error Code : ' + str(msg[0]) + ' Message ' + msg[1])
sys.exit()
except socket.error as msg:
sys.exit()
#print 'Socket bind complete'
def SigHandler(signum = None, frame = None):
try:
Log("Shutdown..")
skt.close()
scheduler.shutdown()
print("")
time.sleep(1) #here check if process is done
SendMessage("Python server stopped", "darkred", "mistyrose")
raise SystemExit
exit()
finally:
Log("Stopped")
os._exit(0)
for sig in [signal.SIGTERM, signal.SIGINT, signal.SIGHUP, signal.SIGQUIT]:
signal.signal(sig, SigHandler)
def DomoticzData(cmd, get=False):
try:
url = URL_DOMOTICZ + cmd
result = requests.get(url)
jsonData = result.json()
if get == True:
return jsonData
elif jsonData["status"] != "OK":
Log("Status " + jsonData["status"] + " for " + cmd)
except(requests.ConnectionError, e):
Log('Request Failed %s - %s' % (e, url) )
def SendMessage(msg, colour="Black", bg="LemonChiffon"):
data = urllib.parse.quote('<font Size="2" COLOR="' + colour + '" style="BACKGROUND-COLOR: ' + bg + '">' + msg + '</font>')
cmd = "command¶m=addlogmessage&message=" + data
threadReqHome = threading.Thread(target=DomoticzData, args=(cmd,))
threadReqHome.start()
svalues = {}
idxes = {}
lastupd = {}
started = False
def StartOnline():
CheckOnline()
scheduler.add_job(CheckOnline, 'interval', seconds = 30)
def StartBattery():
CheckBatteryLevels()
scheduler.add_job(CheckBatteryLevels, 'interval', minutes = 10)
def StartDeleted():
DeleteOldDevices()
scheduler.add_job(DeleteOldDevices, 'interval', minutes = 30)
def StartSTthread():
threadReqHome = threading.Thread(target=RunSpeedTest)
def ProcessData(data):
global svalues, idxes, lastupd
jchanged, jdevices, jidx, jlastupdates = data.split("|")
changed = json.loads(jchanged)
svalues = json.loads(jdevices)
idxes = json.loads(jidx)
lastupd = json.loads(jlastupdates)
Log(list(changed)[0] + " = " + list(changed.values())[0])
global started
if started == False:
started = True
scheduler.start()
scheduler.add_job(StartSTthread, 'interval', minutes = 60)
sch = sched.scheduler(time.time, time.sleep)
sch.enter(5, 1, StartOnline)
sch.enter(10, 1, StartBattery)
sch.enter(15, 1, StartDeleted)
sch.run()
Log("Schedulers started")
def UpdateDevice(device, cmd):
idx = str(idxes[device])
data = 'command¶m=udevice&idx=PARAM_IDX&svalue=PARAM_CMD'
data = data.replace('PARAM_IDX', idx)
data = data.replace('PARAM_CMD', str(cmd))
threadReqHome = threading.Thread(target=DomoticzData, args=(data,))
def DeleteDevice(idx):
data = 'deletedevice&idx=PARAM_IDX'
data = data.replace('PARAM_IDX',str(idx))
def LastUpdated(dd):
DTobj = datetime.strptime(dd['LastUpdate'], '%Y-%m-%d %H:%M:%S')
return datetime.now() - DTobj
def DeleteOldDevices():
jdata = DomoticzData("devices&used=false", True)
if jdata["status"] == "OK":
for dd in jdata['result']:
# print( dd['Name'] + ' ' + dd['LastUpdate'] )
DTdiff = LastUpdated(dd)
if DTdiff.days > 0:
DeleteDevice(dd['idx'])
msg = "Old " + dd['HardwareName'] + ' ' + str(dd['idx']) + ' ' + dd['Type'] + ' ' + dd['SubType']
SendMessage(msg, "darkred")
Log(msg)
# Log("Delete done")
else:
Log("Delete get failed " + jdata["status"])
def CheckBatteryLevels():
if len(svalues) == 0:
return
jdata = DomoticzData("devices&filter=temp&used=true", True)
desc = dd['Description']
if len(desc) > 1 and desc in svalues:
batt = int(dd['BatteryLevel'])
prev = int(svalues[desc])
DTdiff = int(LastUpdated(dd).total_seconds())
if batt >= 0 and batt <= 100 and prev >= 0 and prev <= 100 and batt != prev:
msg = dd['Name'] + ' (' + str(idxes[dd['Name']]) + ') ' + str(prev) + ' -> ' + str(batt) + ' ' + str(DTdiff)
SendMessage(msg)
Log(msg)
svalues[desc] = batt
# Log("Batteries done")
else:
Log("Battery get failed " + jdata["status"])
def CheckOnline():
return
jdata = DomoticzData("devices&filter=utility&used=true&order=Name&plan=2", True)
devices = {}
macaddr = {}
ipp = re.compile('\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}')
macp = re.compile('([0-9a-f]{2}(?::[0-9a-f]{2}){5})', re.IGNORECASE)
macg = re.search(macp, desc)
if macg != None:
devices[dd['Name']] = macg.group()
# Log(dd['Name'] + ' ' + mac.group())
else:
Log("Online get failed " + jdata["status"])
return
with open('/proc/net/arp') as f:
for line in f:
# print(line)
ipg = re.search(ipp, line)
macg = re.search(macp, line)
if ipg != None and macg != None:
# print(ip.group() + ' = ' + mac.group(0))
macaddr[macg.group()] = ipg.group()
for name, mac in devices.items():
stat = svalues[name]
if mac in macaddr:
macip = macaddr[mac]
else:
macip = 'Offline'
if stat != macip:
UpdateDevice(name, macip)
svalues[name] = macip
msg = name + ' is now ' + str(macip)
SendMessage(msg)
Log(msg)
# Log("Online done")
def RunSpeedTest():
Log("Speedtest...")
try:
sp = speedtest.Speedtest()
servers = sp.get_best_server()
ping = str(int(servers['latency']))
UpdateDevice("Ping", ping)
dnld = sp.download()
dwn = "{:.2f}".format(dnld/1000000)
UpdateDevice("Download", dwn)
upld = sp.upload()
up = "{:.2f}".format(upld/1000000)
Log(up + " " + dwn + " " + ping + "ms " + servers['name'])
except:
Log("Failed")
SendMessage("Speedtest failed", "darkred")
SendMessage("Python server ready...")
Log("Started")
#Function for handling connections. This will be used to create threads
def ClientThread(conn):
data = ""
BUFF_SIZE = 4096
while True: # Read all of the sent data
#Receiving from client
part = conn.recv(BUFF_SIZE)
data += part.decode('utf-8')
if len(part) < BUFF_SIZE:
break
conn.close()
# reply = 'OK...' + data
# conn.sendall(reply)
if len(data) > 0:
ProcessData(data)
#now keep talking with the client
while True:
#wait to accept a connection - blocking call
conn, addr = skt.accept()
# print 'Connected with ' + addr[0] + ':' + str(addr[1])
#start new thread takes 1st argument as a function name to be run, second is the tuple of arguments to the function.
threading.Thread(target=ClientThread, args=(conn,)).start()
skt.close()
