EspEasy Wemos Mini and push button notification
Posted: Saturday 22 April 2017 17:38
by ensingg
Sorry, I am a newbie. Tried reading many wikis but still too much information.
I like to have a push button connected to my ESP8266 and when I press it, I like to get a notification from Domoticz.
I configured ESPEasy with a device. But don't know what to do in Domoticz.
Please be patient and help me ;-)
Best regards,
Gert
Re: EspEasy Wemos Mini and push button notification
Posted: Saturday 22 April 2017 18:57
by Toulon7559
Shorthand writing, but this in summary gives the idea [the ESPEasy Wiki describes in more detail]:
1. Go to Domoticz, Setup, Hardware
2. Create Dummy with Switch => will create Switch Device
3. Go to Domoticz, Setup, Devices
4. Under Hardware look for Dummies
5. Take note of the IDX for the Switch you created under 2.
6. Use that IDX in ESPEasy, Devices to identify your switch
7. Then in Domoticz use the information in your application
Posted: Saturday 22 April 2017 19:51
by Eawo
I also have this problem with a sonoff with easyesp it just won't work with idx not sure what I'm doing wrong it works great using http link.
And it works fine with http but if I use idx I can use the push button and see the relay changes off/on
Do I need to have a mtqq client to get idx working?
Posted: Saturday 22 April 2017 20:10
by Westcott
Hi Eawo,
Can you post screenshots of your ESPeasy and Domoticz device pages, please?
And no, you don't need MQTT.
Posted: Sunday 23 April 2017 13:16
by Eawo
OK heres my settings plz tell if u want more info :D
And in Domoticz Log it says this 2017-04-23 13:17:13.354 User: Eawo initiated a switch command (46/Sonoff/On)
Posted: Sunday 10 February 2019 20:01
by griztoof
hi,
have anyone the solution ?
I have the same matter without solution. i spend a lot of time to reading forums …
My esp switch when i press the button, but domoticz Don't change the status of the button. (the IDX is well informed)
Posted: Sunday 10 February 2019 20:29
by marcojpolet
Did you also read the help page for Domoticz MQTT? It also says:
MQTT Client Gateway with LAN interface"
https://www.letscontrolit.com/wiki/inde ... oticz_MQTT
Perhaps you missed that?
Is there a reason you want MQTT? I use Domoticz HTTP and this works fine.
Also you might consider installing a more recent version of esp easy? I use the mega branch which works quite good.
Regards,
Marco
Posted: Monday 11 February 2019 23:43
by griztoof
Thanks à lot, I've try http and it works fine
