Hi to all,
i've made a .vbs for launch spotify and play my favourites playlist and this work fine from windows.
in domoticz I created a virtual switch with the command to start the VBS files but nothing happens even in the logs seems everything started correctly
Where is the problem!?
VBS Work on windows but not in Domoticz
SweetPants
Re: VBS Work on windows but not in Domoticz
What happens if you execute the script from a .bat file?
zak45
- Domoticz version: V2024.4
I would do it in this way:
create a cmd file e.g. c:\playmagnifica.cmd
put on it:
cmd /c start cscript c:\playmagnifica.vbs
In this way you will go back to Domoticz very quickly, otherwise could fail if more than 10 seconds.
And this should work.
lets try.
put on it:
lets try.
ilpier
@SweetPants idem if execute VBS script from a .bat
If i launch .bat from windows work if ilaunch from Domoticz in log "Execute script.." but nothing happens.
@zak45 .cmd work on windows but in domoticz no way and in log "Error: SQLHelper: Error script not found 'C:\playmagnifica.cmd'" it seems that domoticz might not start as a .cmd script
ilpier
it's very strange...
in Taskmgr i see this
but Spotify don't start...
Same if i use .bat or .vbs
