Unfortunately I use to connect remotely to domoticz from a site where I do not have access to ssh or (in general) to the file system...
Can be a solution to allow to save as file a lua script from the event editor directly to the file system?
The EventType will add the prefix script_trigger_ and the script name wil be added automatically...
Once saved the event can be turned off (and maybe add a comment line in the event script)
-- Saved as scitp_trigger_name.lua to LUA folder on timestamp
the file could be overwritten every time you save with the same name
it was just an idea
