LUA || Qubino Dimmer || State "On"
Posted: Sunday 09 April 2017 20:23
Hi Guys,
Since this is my first post to the forum i apologize in advance for any faults or in-regulations.
I have my own house for a month now, so i can finally expand my hobby in domotica..
I created the script below to automate some of the lighting in my house..
My problem, better said challenge is this:
When it is light enough in various rooms (this is determined by the variables w,g and o) i want the system to turn off the lights again.
This work perfectly for the lights in my living room (w). I think because this is a dimmer, but switch mode is set to "On/Off".
However it doesn't work for the light in my hallway (g and o), probably because these two are set to switch type "Dimmer".
Through some debugging i found out that my problem is the if statement below, it doesn't match:
if otherdevices['Gang']=='On' then
Strange enough it does match when specified as "Off".. Could this be because if the light is dimmed the correct value is not "On"?
Any help would be appreciated.
Hardware: Qubino ZMNHDD1 Flush Dimmer
Software: Domoticz version: 3.7267 on a Raspberry Pi
-- Script voor het automatisch regelen van sommige verlichting in de avond en nacht.
-- Gemaakt door Tim Reijnen.
w=tonumber(otherdevices['Lichtsterkte Woonkamer']) --> De lichtsterkte van de woonkamer wordt opgelagen in variable 'w'
g=tonumber(otherdevices['Lichtsterkte Gang']) --> De lichtsterkte van de gang wordt opgelagen in variable 'g'
o=tonumber(otherdevices['Lichtsterkte Overloop']) --> De lichtsterkte van de overloop wordt opgelagen in variable 'o'
-- Gedeelte voor de verlichting in de woonkamer
if otherdevices['Iemand Thuis']=='On' then --> Als er iemand thuis is...
if w <= 5 then --> En de lichtsterkte minder dan 5 lux is...
if devicechanged['Beweging Woonkamer']=='On' then --> En er beweging is gedetecteerd in de woonkamer...
commandArray['Plafondlamp Keuken']='Set Level 1' --> Doe ik ze aan voor jullie...
if w <= 10 then --> En de lichtsterkte minder dan 10 lux is...
if otherdevices['Lampen Televisie']=='Off' then --> En de lampen bij de televisie niet aan zijn...
commandArray['Lampen Televisie']='On' --> Doe ik ze aan voor jullie...
if w > 5 then --> Als de lichtsterkte meer dan 5 lux is...
if otherdevices['Plafondlamp Keuken']=='On' then --> En de lampen in de keuken zijn nog aan...
commandArray['Plafondlamp Keuken']='Off' --> Doe ik die uit voor jullie...
if w > 10 then --> Als de lichtsterkte meer dan 10 lux is...
if otherdevices['Lampen Televisie']=='On' then --> En de lampen bij de televisie nog aan zijn...
commandArray['Lampen Televisie']='Off' --> Doe ik ze uit voor jullie...
if otherdevices['Iemand Thuis']=='Off' then --> Als er niemand (meer) thuis is...
if otherdevices['Lampen Televisie']=='On' then --> En de lampen bij de televisie zijn nog aan.
commandArray['Lampen Televisie']='Off' --> Doe ik ze uit...
commandArray['Plafondlamp Keuken']='Off' --> Doe ik ze uit...
-- Gedeelte voor de verlichting in de gang
if g <= 10 then --> Als de lichtsterkte in de gang minder dan 10 Lux is...
if otherdevices['Gang']=='Off' then --> En als de lamp in de gang nog uit is...
commandArray['Gang']='Set Level 15' --> Doe ik de lamp vast gedimt aan...
if devicechanged['Beweging Gang']=='On' then --> En als er beweging is gedetecteerd in de gang...
if uservariables['dagdeel']=='Middag' or uservariables['dagdeel']=='Avond' or uservariables['dagdeel']=='Ochtend' then --> En het middag, avond of ochtend is...
commandArray['Gang']='Set Level 100' --> Doe ik de lamp daar even wat feller...
if uservariables['dagdeel']=='Nacht' then --> Maar als het nacht is...
commandArray['Gang']='Set Level 35' --> Doe ik de lamp daar even wat feller, maar minder fel omdat het nacht is...
if devicechanged['Beweging Gang']=='Off' then --> Als er geem beweging meer is gedetecteerd in de gang...
commandArray['Gang']='Set Level 15' --> Dim ik daar de lamp weer...
if g > 10 then --> Als de lichtsterkte in de gang meer dan 10 Lux is...
if otherdevices['Gang']=='On' then --> En als de lamp in de gang nog aan is...
commandArray['Gang']='Set Level 0' --> Doe ik die uit.
-- Gedeelte voor de verlichting op de overloop
if o <= 10 then --> Als de lichtsterkte op de overloop minder dan 10 Lux is...
if otherdevices['Overloop']=='Off' then --> En als de lamp op de overloop nog uit is...
commandArray['Overloop']='Set Level 15' --> Doe ik de lamp vast gedimt aan...
if devicechanged['Beweging Overloop']=='On' then --> En als er beweging is gedetecteerd op de overloop...
commandArray['Overloop']='Set Level 100' --> Doe ik de lamp daar even wat feller...
commandArray['Overloop']='Set Level 35' --> Doe ik de lamp daar even wat feller, maar minder fel omdat het nacht is...
if devicechanged['Beweging Overloop']=='Off' then --> Als er geem beweging meer is gedetecteerd op de overloop...
commandArray['Overloop']='Set Level 15' --> Dim ik daar de lamp weer...
if o > 10 then --> Als de lichtsterkte op de overloop meer dan 10 Lux is...
if otherdevices['Overloop']=='On' then --> En als de lamp in de gang nog aan is...
commandArray['Overloop']='Set Level 0' --> Doe ik die uit.
