New Ethernet Relay board includes 48 Power Relays and local expansion capability
Posted: Sunday 09 April 2017 20:13
Intelligent-Appliance announced a new Industrial Relay board supporting 48 Power Relays and a local expansion capability of handling hundreds of relays through a single IP port.
This latest addition to Intelligent-Appliance Power Relay Controllers, the IA-3152-E, is TCP/IP controlled, based on 48 Power Relays, with a current rating of 7 Amps at 250VAC or 30VDC, handling a total of 60KVA or 7.2KW.
Each IA-3152-E board includes 8 Relay groups. Each group is wired separately in order to fit a separate Circuit Breaker for each group for additional safety and control.
Handling several to tens of card on each location is made easy thanks to the Series-3000 command set which includes board address within the command.
Continue Reading :- http://www.intelligent-appliance.com/ne ... aspx?id=43
