I have a question. I have a AEOTEC Z-Stick on my Pi and two Neo Coolcam power plugs.
They both work great. I have only one question. I want to create a scheduled task to turn off and turn on the switch.
So like :
turn off at 23:00
turn on at 06:00
turn off at 08:00
turn on at 17:00
Is this possible?
Create scheduled task for Zwave Powerplug?
i000
Re: Create scheduled task for Zwave Powerplug?
Hi! You use Domoticz? If you use you can go to settings, event, and create the task with blocks.
pvm
- Domoticz version: 4.10538
Or use a timer (property of the switch ) for that purpose. Even easier
PDP8
- Domoticz version: V4.9700
I have the same question. I can make events, not a big deal.
But how do I explain to others to change the time settings?
I would like to have a simple user interface on the dashboard where a non
technician simply can set a time and a task like 'turn on lamp'...
In my case the Pi has a gpio pin for the lamp. So no hardware timer available.
jslegers
- Domoticz version: 2025.2
Thank you I will test it these days. I'm using it on a Rpi.
