Can you help me please
10:09:17.579677 T80190000 Read-Data Boiler water temperature: 0.00
10:09:17.633941 Command (via relay server, from 127.0.0.1:43940): SC=10:09/6
10:09:17.654134 PR: SE
10:09:17.656664 Command (via relay server, from 127.0.0.1:43940): PR=G
10:09:17.657762 Command (via relay server, from 127.0.0.1:43940): PR=I
10:09:17.658819 Command (via relay server, from 127.0.0.1:43940): PR=O
10:09:17.659742 Command (via relay server, from 127.0.0.1:43940): PS=1
10:09:17.672535 PR: G=00
10:09:17.682711 PR: I=00
10:09:17.715439 B40192319 Read-Ack Boiler water temperature: 35.10
10:15:17.993516 Command (via relay server, from 127.0.0.1:43940): SC=10:15/6
10:15:18.019017 SC: 10:15/6
10:15:18.021416 Command (via relay server, from 127.0.0.1:43940): PR=G
10:15:18.022423 Command (via relay server, from 127.0.0.1:43940): PR=I
10:15:18.023306 Command (via relay server, from 127.0.0.1:43940): PR=O
10:15:18.025792 Command (via relay server, from 127.0.0.1:43940): PS=1
10:15:18.037310 PR: G=00
10:15:18.047549 PR: I=00
0:15:01.205038 Command (via websocket): PS=1
10:15:01.217685 PS: 1 >>>> (1) Manual PS=1
10:15:01.390263 00000010/00000000,10.00,00000011/00000011,100.00,0/0,20.00,0.00,0.00,20.00,34.30,0.00,0.00,33.30,60/40,61/20,60.00,61.00,65535,42528,45504,28720,6656,21088,56016,832
10:15:18.019017 SC: 10:15/6 >>>> (2) SC command - first one - succeeds
10:15:47.999630 Command (via relay server, from 127.0.0.1:43940): SC=10:15/6
10:15:48.019857 PR: SE >>>> (3) SC command - first one - failes
10:15:48.022457 Command (via relay server, from 127.0.0.1:43940): PR=G
10:15:48.023707 Command (via relay server, from 127.0.0.1:43940): PR=I
10:15:48.024607 Command (via relay server, from 127.0.0.1:43940): PR=O
10:15:48.025670 Command (via relay server, from 127.0.0.1:43940): PS=1
10:15:48.038358 PR: G=00
10:15:48.048739 PR: I=00
10:16:18.004395 Command (via relay server, from 127.0.0.1:43940): SC=10:16/6
10:16:18.024584 PR: SE >>>> (4) SC command - first one - failes
10:16:18.026828 Command (via relay server, from 127.0.0.1:43940): PR=G
10:16:18.027878 Command (via relay server, from 127.0.0.1:43940): PR=I
10:16:18.028929 Command (via relay server, from 127.0.0.1:43940): PR=O
10:16:18.029846 Command (via relay server, from 127.0.0.1:43940): PS=1
10:16:18.042660 PR: G=00
10:16:18.052879 PR: I=00
10:16:43.972699 Command (via websocket): PS=1
10:16:43.986527 PR: SE >>>> (5) Manually submits PS=1, first attempt fails
10:16:45.974271 Command (via websocket): PS=1
10:16:45.987166 PS: 1 >>>> (6) Manually submits PS=1, second attempt succeeds
10:16:46.159749 00000010/00000000,10.00,00000011/00000011,100.00,0/0,20.00,0.00,0.00,20.00,34.10,0.00,0.00,33.00,60/40,61/20,60.00,61.00,65535,42528,45504,28720,6656,21088,56016,832
10:16:48.015357 Command (via relay server, from 127.0.0.1:43940): SC=10:16/6
10:16:48.040782 SC: 10:16/6 >>>> (7) SC command - first one - succeeds
10:16:48.043230 Command (via relay server, from 127.0.0.1:43940): PR=G
10:16:48.044284 Command (via relay server, from 127.0.0.1:43940): PR=I
10:16:48.045204 Command (via relay server, from 127.0.0.1:43940): PR=O
10:16:48.046130 Command (via relay server, from 127.0.0.1:43940): PS=1
10:16:48.059164 PR: G=00
10:16:48.069485 PR: I=00
10:17:18.020029 Command (via relay server, from 127.0.0.1:43940): SC=10:17/6
10:17:18.040252 PR: SE >>>> (6) SC command - first one - failes
10:17:18.042905 Command (via relay server, from 127.0.0.1:43940): PR=G
10:17:18.044184 Command (via relay server, from 127.0.0.1:43940): PR=I
10:17:18.045199 Command (via relay server, from 127.0.0.1:43940): PR=O
10:17:18.046266 Command (via relay server, from 127.0.0.1:43940): PS=1
10:17:18.058943 PR: G=00
10:17:18.069089 PR: I=00
