which weather station for solar radiation to get
mongoose
Post by mongoose »
In New Zealand I can't get solar radiation nor UV on weather underground. I can get predicted however at http://solarview.niwa.co.nz/ (if anyone is interested)
But so thought about buying a weather station that does solar radiation, google came up with this one http://www.amazon.co.uk/Weather-Station ... B00C9MFQ1A (also available here) but would it work with rfxcom? does anyone else have a weather station from AERCUS Instruments. as would be cool if it uses the same protocols as La Crosse or Oregon scientific etc...
cheers
Larry
b_weijenberg
Re: which weather station for solar radiation to get
Post by b_weijenberg »
The Oregon Scientific UVN800 is received by the RFXtrx
http://www.oregonscientificstore.com/UV ... or.product
RFX-433, RFX-433EMC, RFX-868
BristolBaz
Post by BristolBaz »
I got solar and UV from Forecast IO - http://forecast.io/#/f/-41.4395,172.1936
Derik
Post by Derik »
BristolBaz wrote:I got solar and UV from Forecast IO - http://forecast.io/#/f/-41.4395,172.1936
Me to...
Only i do not understand the data..
what is the forecast time. how many hours in the future?
I will see in the summer., or the data is correct.... :D :D
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
Difficult to understand what the Forecast-values are.
If you compare with calculation results of http://re.jrc.ec.europa.eu/pvgis/apps4/pvest.php# for Monthly Radiation or Daily Radiation no resemblance can be seen .....
Toulon7559
Perhaps this thread in this forum is an interesting entry to getting rough-order-of-magnitude info on local solar radiation, somewhat compensated for actual weather: http://www.domoticz.com/forum/viewtopic ... 23&t=10077
Question for you is which station in your vicinity provides a practical Octa-value
