Some Livolo setup tips
Posted: Sunday 09 February 2014 22:36
by Cowchaser
I thought to share some info on the Livolo setup
After some experimenting I can confirm that the Livolo EU touch switches/dimmers are working with Domoticz and the RFXtrx 433 USB.
I've now setup 2 dimmers and a 2-way switch. Material looks great and build quality is OK.
Some (hopefully) helpful tips & tricks below.
You can't just swap out your existing 2-way switches with existing wiring but need to use the Livolo schematics to make everything work (by using the COM line to interconnect the 2 switches)
Not really Domoticz related but I've also ordered some power sockets to match the switches. To make a combined dimmer power-socket comboin a dual-wallbox I swapped out a socket for a dimmer and found out that it didn't fit together very well since after closer inspection the silver frame surrounding the power socket differs slightly from the dimmer frame.
However after swapping the frame everything fits together perfectly.
The dimmers can replace either one way switches or existing dimmers. Wattage indicated in the specs. is 25W to 500W, meaning that low watt LED setups can also work. (I tested with 4 x 2W 230V LED lights and it's working OK despite some buzzing noise in the LED's.)
Now back on topic to Domoticz...
Initially I could only get one dimmer to work in Domoticz by using ID #0 and sub-ID #0. The other switches simply didn't work with Domoticz.
Eventually I found I had to hold the touch button longer to reset the switch and afterwards enable Domoticz to pair an ID. Below a step by step tutorial:
In Domoticz make preparations by manually entering a new Livolo switch or dimmer with a unique name, ID and sub-ID. (Note: you choose the ID and sub-ID yourself)
Before hitting the 'Test'-Button in Domoticz basically you hold the touch area on the Livolo switch/dimmer.. after about 5 seconds you hear a beep but keep holding the button until you hear a second beep. This means the switch has been reset.
Let go of the touch button and press it again for about 5 seconds until you hear a single beep. Let go again and immediately click "Test" in Domoticz.
The switch/dimmer will respond with a beep indicating the pairing is succesful.
You should now be able to use the 'Test' button to toggle the lights.
I will be adding a dozen extra Livolo switches and dimmers to the setup soon and will provide more feedback afterwards.
Re: Some Livolo setup tips
Posted: Friday 14 February 2014 16:36
by Heisenberg
Great to see that Livolo is compatible with Domoticz and RFXtrx433 and thanks for the instructions.
I was looking for Livolo and Kopau RF switches but was afraid it didn't work without good documentation.
Could you also post a link which Livolo models you bought?
Posted: Wednesday 05 March 2014 20:59
by nigels0
Posted: Tuesday 28 April 2015 19:08
by Isty1974
Reset is done on Switch.
I've tried to Add it automatically, doesn't worked.
After manually addon, only the power off function working :(
Pairing does not work well for me. (build no. v2.2385.)
Posted: Sunday 03 May 2015 11:14
by Cannon
Does it show the state of the lights correctly on domoticz?
Posted: Monday 04 May 2015 12:09
by jjnj
Cannon wrote:Does it show the state of the lights correctly on domoticz?
No it doesn't. It you manually switch it on you will not see it in Domoticz
Posted: Monday 04 May 2015 20:37
by Cannon
What if you just used a normal livolo and put a micro controller in behind?
Sent from my SM-N9005 using Tapatalk 2
Posted: Monday 21 March 2016 10:50
by rickwilleme
I'm also looking into the Livolo dimmers with remote function.
Can I send for example a 'dim to 50%'-command from Domoticz?
Posted: Monday 21 March 2016 12:21
by b_weijenberg
The Livolo dimmer is controlled by the RFXtrx433 with dim and bright commands.
Domoticz is using this function to set the dimmer to a dim level with a selection of 6 steps: 16, 33, 50, 66, 83 and 100%
Posted: Tuesday 12 April 2016 13:50
by SHadley1138
I hold the button in, but never hear a beep, just the relay fire.... Am I doing something wrong?
Posted: Wednesday 13 April 2016 18:41
by hayman
thanks for the info it's very handy
Posted: Monday 25 April 2016 19:11
by hayman
hello ,
i've just pair a dimmer (livolo) to my domoticz (synology usb rfxE)and it's work okey but when i dim the light it's goes off after that on ,to the level i chooes,and i light it up it's goes first off after that to 100%.....!!!!!!
is there any thing i can do that make it work normal without goning OFF ,
thanks again
Posted: Tuesday 03 May 2016 17:19
by hayman
please is there any one with that isso...?
Posted: Tuesday 03 May 2016 19:02
by b_weijenberg
Livolo does not have a set dim level.
The only way to set the dimmer to a dim level is to switch the module OFF and transmit several bright commands to put the dimmer module at the required dim level.
Posted: Tuesday 03 May 2016 21:30
by hayman
okey clear to me know thanks a lot
Posted: Tuesday 14 February 2017 20:23
by tontze
Anyone tried these livolos with RFLink ?
Posted: Wednesday 22 February 2017 21:38
by icibt
tontze wrote:Anyone tried these livolos with RFLink ?
I did... they work fine, but there is only the Toggle option. You can't sent and OFF or ON. So no way to implement this switch in a scene without knowing its previous state. I know the Livolos have a MasterOff option... but haven't been able to implement it yet. I'm still waiting for my livolo remote to arrive... than I will see what exactly is the remote sending.
Posted: Wednesday 01 March 2017 11:12
by piffmasta
Hi! I tried witth rflinkgw. What i figured out, that when synced with domo and rflink I can send 0000 to switch all off. But I also have a remote from livolo and when syncing the switch with it, I can also send with the highest button on it an all off command. So I think its possible to send an unique OFF with this all-off feature when syncing it with several remotes or the sepcific code from the drop down fields. but when listing devices there a differences with the len in the id field and when learning the remote, all buttons do have the same ID... am I missing something? I also dont understand why the send commands are different on the serial output... the 2a switch is button 4 on my remote, but how the liv switches do know, that they are ment by the remote and why its not possible to configure them in the gui according to the learn-swith (which are different)...
Posted: Saturday 05 February 2022 17:58
by daniellejorge
Cowchaser wrote: Sunday 09 February 2014 22:36 Below a step by step tutorial:
I put switch type : On/off, Type: Livolo
This works , it pairs the Lovolo switch, but when i click on, it turns on,
when i click OFF it turns off and back on.
Anyone knows how to fix this?
