I have a blocky going for when a shed door is opened.
I want it to go off just the once, but it seems to repeat setting everything off again every 3-5 minutes, (not timed it, damn annoying).
What command can i pop in there so it only occurs the once (when triggered)?
https://drive.google.com/open?id=0B9Tgf ... mR3XzhLX1U
Stuart
Script being repeated every few minutes
stuiow
- Domoticz version: 3.6857
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
Lebo2d9
- Domoticz version: L stab
Re: Script being repeated every few minutes
Hi Stuart,
Is the sensor not sending it status each 3-5 minutes. Maybe you can add an extra dummy with the previous state of your sensor.
If you sensor state and the previous state is equal then nothing should happen. If the sensor state and the previous staet is different that you preform your actions and also update the state of you dummy switch to the new state.
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
More to come
stuiow
Ive a similar blocky script involving windows, but doesnt contain anything about times, that works fine. This script is a real pain for repeatinly sounding alarm and lighting lights.
I like your thought on the dummy switch, i'll look into that. Cheers
gerardvs
- Domoticz version: latest-1
By design scripts have no knowledge of previous activity. The status could be stored in a dummy switch as stated in an earlier post or you could use a "user variable" to store the actual status. In your script you could check the status and take action.... or not.
Haha
... "Or not".... Buy the way thanx for your advices and tips
I like to listen orchestra music. Because I feel the melody and style of playing on different instruments
