Evohome - RFG100
mschut
Domoticz version: V3.5613
Evohome - RFG100
Post by mschut »
Although the question was also mentioned within the "Synology package" thread, I do post is specially here.
I am trying to connect my Evohome with a RFG100 (after trying for ages on the Pi with a HGI80, I just couldn't get it stable).
However, I am almost done with the steps to connect it according to the Wiki, but I encounter 1 issue along the way I can not solve (yet).
This is:
Create the initial Domoticz hardware device and zones make sure Python and the evohome-client are installed before running this
evo-update.sh init
This results in the error:
INFO:urllib3.connectionpool:Starting new HTTPS connection (1): tccna.honeywell.com
  File "//home/pi/evohome-client/evo-update.sh", line 29, in <module>
    client = EvohomeClient(evoconfig.usr,evoconfig.pw)
  File "/home/pi/evohome-client/evohomeclient2/__init__.py", line 18, in __init__
    self._login()
  File "/home/pi/evohome-client/evohomeclient2/__init__.py", line 76, in _login
    self.installation()
  File "/home/pi/evohome-client/evohomeclient2/__init__.py", line 86, in installation
    r = requests.get('https://tccna.honeywell.com/WebAPI/emea/api/v1/location/installationInfo?userId=%s&includeTemperatureControlSystems=True' % self.account_info['userId'], headers=self.headers)
TypeError: list indices must be integers, not str
I checked my credentials, and even did a reset to be sure, so I am certain the credentials are correct.
What can be wrong?
mschut
Re: Evohome - RFG100
Post by mschut »
Thanks, but even after some reading and trying, I am stuck...
Could you help me a bit. I did first follow the instructions on the Wiki, including the evohome-client. To be sure, is the wiki https://www.domoticz.com/wiki/Evohome#S ... _or_RFG100 not complete? It does install the client, or should I upgrade?
