Event before sunrise? Topic is solved
MatthijsD
Post by MatthijsD »
I'm struggeling with activating a scene 1,5 hour before sunset.
This is what I got so far:
I think the '90' is not recognized as minutes, but I don't know how to get it right.
Does anyone know how to do this right?
gerard76
Domoticz version: 3.8153
Re: Event before sunrise?
Post by gerard76 »
You cannot do calculations in Blockly AFAIK. You can use LUA to do what you want OR set your lat-lng to some place where the sun sets 1.5 hours earlier and then just trigger the blocky on sunset.
gerardvs
Domoticz version: latest-1
Post by gerardvs »
Or use a dummy switch. Let that switch go on 1.5 hrs before sunset. From blocky you could read the status of the dummy switch so you "know' when it's time to do something.
Lebo2d9
Domoticz version: L stab
Re: RE: Re: Event before sunrise?
Post by Lebo2d9 »
gerardvs wrote:Or use a dummy switch. Let that switch go on 1.5 hrs before sunset. From blocky you could read the status of the dummy switch so you "know' when it's time to do something.
I use also a dummy switch where i set the timer
Verstuurd vanaf mijn SM-G920F met Tapatalk
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
MatthijsD
Post by MatthijsD »
Yes, thanks everyone.
The use of a switch is the way to go!
