2 raspberrys and ot gateway challenge
For OpenTherm-gateway related questions in Domoticz
tiga
Post by tiga »
i have 2 raspberrys.
1 central with a rfxcom, and 1 nearby my boiler with the gateway(usb connected)
both are running up to date domoticz.
i setup a Domoticz - Remote Server on my central one
and added user with admin?(beheerder) rights on my gateway one.
all communicates great but when i want to adjust the setpoint of the thermostat (on my central raspberry) nothing seems to happen.
but when i look in my device list it added a new device in the unused section with the setpoint...
am i doing something impissible or wrong?
tiga
Re: 2 raspberrys and ot gateway challenge
Post by tiga »
update...
when adding that new device on my central raspberry end adjusting the value....
it creates a new device on my open therm raspberry.
so it seems that the communication is being split up between the raspberry's.
tiga
Post by tiga »
anyone??
ernorv
Post by ernorv »
Why not simply run the otmonitor on the gateway version and let your central one connect directly to the tcp port exposed by otmonitor? No need for a second Domoticz for just this reason.
adsernl
Post by adsernl »
all,
i have the same issue, does someone have an idea whats wrong?
bitjeverkeerd
Post by bitjeverkeerd »
I have the same hardware setup and last winter this worked perfectly. I now live in a different house with a newer domoticz version on both pi's and I have the same issue now, I can no longer control the setpoint from the main pi
