Connecting to MySensors MTTQ gateway
Posted: Wednesday 29 March 2017 7:24
After a lot of reading and trial and error I have the following:
Domoticz + NodeJS + Mosquitto + NodeRed in a Raspberry Pi running Jessie build
Gateway ESP8266MTTQ Client running the default code
And a simple button switch arduino uno
I'm not seeing any values being updated in Domoticz, so I think something is configured incorrectly but don't know what.
There is no error in the log and already tried using the dummy temp device and send a mosquitto_pub from within raspberry pi.
Can someone explain these different IPs?
ESP Gateway
Node with switch sensor
ESP output
Switch Node output
Any help making the setup work is appreciated
mosquitto_pub -h localhost -m '{ "idx" : 1, "nvalue" : 0, "svalue" : "25.0" }' -t 'domoticz/in'Code: Select all
2017-03-28 21:19:50.703 Domoticz V3.7196 (c)2012-2017 GizMoCuz
2017-03-28 21:19:50.709 Build Hash: 7a224cd, Date: 2017-03-28 11:40:00
2017-03-28 21:19:50.709 System: Raspberry Pi
2017-03-28 21:19:50.710 Startup Path: /home/pi/domoticz/
2017-03-28 21:19:51.230 PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2017-03-28 21:19:51.292 Active notification Subsystems: gcm, http (2/12)
2017-03-28 21:19:51.319 WebServer(HTTP) started on address: :: with port 8080
2017-03-28 21:19:51.358 WebServer(SSL) started on address: :: with port 443
2017-03-28 21:19:51.364 Proxymanager started.
2017-03-28 21:19:51.372 Starting shared server on: :::6144
2017-03-28 21:19:51.377 TCPServer: shared server started...
2017-03-28 21:19:51.378 RxQueue: queue worker started...
2017-03-28 22:06:32.265 EventSystem: reset all events...
2017-03-28 22:06:32.270 EventSystem: reset all device statuses...
2017-03-28 22:06:32.278 EventSystem: Started
2017-03-28 22:06:33.268 MQTT: Connecting to localhost:1883
2017-03-28 22:06:33.385 MQTT: connected to: localhost:1883
2017-03-28 22:06:33.386 MySensorsMQTT: connected to: localhost:1883
2017-03-28 22:06:33.488 MQTT: Subscribed
2017-03-28 22:07:19.821 Incoming connection from: 192.168.1.5
// Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP)
#define MY_IP_ADDRESS 192,168,1,163 //I think this is the static IP that I'm setting for my ESP8266 gateway
// If using static ip you need to define Gateway and Subnet address as well
#define MY_IP_GATEWAY_ADDRESS 192,168,1,1 //Not sure if this is correct
#define MY_IP_SUBNET_ADDRESS 255,255,255,0
// MQTT broker ip address.
#define MY_CONTROLLER_IP_ADDRESS 192,168,1,125 // I think this is the IP address of the rapberry pi running Domoticz
ESP Gateway
* The MySensors Arduino library handles the wireless radio link and protocol
* between your home built sensors/actuators and HA controller of choice.
* The sensors forms a self healing radio network with optional repeaters. Each
* repeater and gateway builds a routing tables in EEPROM which keeps track of the
* network topology allowing messages to be routed to nodes.
* Created by Henrik Ekblad <[email protected]>
* Copyright (C) 2013-2015 Sensnology AB
* Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
* Documentation: http://www.mysensors.org
* Support Forum: http://forum.mysensors.org
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* version 2 as published by the Free Software Foundation.
* REVISION HISTORY
* Version 1.0 - Henrik Ekblad
* DESCRIPTION
* The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
* The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
* LED purposes:
* - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
* - RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
* - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
* - ERR (red) - fast blink on error during transmission error or recieve crc error
* See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
* https://www.mysensors.org/build/connect_radio
* nRF24L01+ ESP8266
* VCC VCC
* CE GPIO4
* CSN/CS GPIO15
* SCK GPIO14
* MISO GPIO12
* MOSI GPIO13
* Not all ESP8266 modules have all pins available on their external interface.
* This code has been tested on an ESP-12 module.
* The ESP8266 requires a certain pin configuration to download code, and another one to run code:
* - Connect REST (reset) via 10K pullup resistor to VCC, and via switch to GND ('reset switch')
* - Connect GPIO15 via 10K pulldown resistor to GND
* - Connect CH_PD via 10K resistor to VCC
* - Connect GPIO2 via 10K resistor to VCC
* - Connect GPIO0 via 10K resistor to VCC, and via switch to GND ('bootload switch')
* Inclusion mode button:
* - Connect GPIO5 via switch to GND ('inclusion switch')
* Hardware SHA204 signing is currently not supported!
* Make sure to fill in your ssid and WiFi password below for ssid & pass.
// Enable debug prints to serial monitor
#define MY_DEBUG
// Use a bit lower baudrate for serial prints on ESP8266 than default in MyConfig.h
#define MY_BAUD_RATE 9600
// Enables and select radio type (if attached)
#define MY_RADIO_NRF24
//#define MY_RADIO_RFM69
#define MY_GATEWAY_MQTT_CLIENT
#define MY_GATEWAY_ESP8266
// Set this node's subscribe and publish topic prefix
#define MY_MQTT_PUBLISH_TOPIC_PREFIX "domoticz/in/MyMQTT"
#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "domoticz/out/MyMQTT"
// Set MQTT client id
#define MY_MQTT_CLIENT_ID "mysensors-1"
// Enable these if your MQTT broker requires usenrame/password
//#define MY_MQTT_USER "username"
//#define MY_MQTT_PASSWORD "password"
// Set WIFI SSID and password
#define MY_ESP8266_SSID "xxxxxxxxx" // "MySSID" - removed
#define MY_ESP8266_PASSWORD "xxxxxxxxxxxx" // "MyVerySecretPassword" - removed
// Set the hostname for the WiFi Client. This is the hostname
// it will pass to the DHCP server if not static.
// #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
// The MQTT broker port to to open
#define MY_PORT 1883
// Enable inclusion mode
#define MY_INCLUSION_MODE_FEATURE
// Enable Inclusion mode button on gateway
#define MY_INCLUSION_BUTTON_FEATURE
// Set inclusion mode duration (in seconds)
#define MY_INCLUSION_MODE_DURATION 60
// Digital pin used for inclusion mode button
#define MY_INCLUSION_MODE_BUTTON_PIN 3
// Set blinking period
#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Flash leds on rx/tx/err
#define MY_DEFAULT_ERR_LED_PIN 16 // Error led pin
#define MY_DEFAULT_RX_LED_PIN 16 // Receive led pin
#define MY_DEFAULT_TX_LED_PIN 16 // the PCB, on board LED
#include <ESP8266WiFi.h>
#include <MySensors.h>
void setup()
void presentation()
// Present locally attached sensors here
void loop()
// Send locally attech sensors data here
// MY_MQTT_PUBLISH_TOPIC_PREFIX/FROM-NODE-ID/SENSOR-ID/CMD-TYPE/ACK-FLAG/SUB-TYPE
* DESCRIPTION
* Simple binary switch example
* Connect button or door/window reed switch between
* digitial I/O pin 3 (BUTTON_PIN below) and GND.
* http://www.mysensors.org/build/binary
#define MY_DEBUG
//#define MY_NODE_ID 6
// Enable and select radio type attached
#include <SPI.h>
#include <Bounce2.h>
#define CHILD_ID 3
#define BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
Bounce debouncer = Bounce();
int oldValue=-1;
// Change to V_LIGHT if you use S_LIGHT in presentation below
MyMessage msg(CHILD_ID,V_TRIPPED);
void setup()
// Setup the button
pinMode(BUTTON_PIN,INPUT);
// Activate internal pull-up
digitalWrite(BUTTON_PIN,HIGH);
// After setting up the button, setup debouncer
debouncer.attach(BUTTON_PIN);
debouncer.interval(5);
Serial.begin(9600); // initialize serial
void presentation() {
// Register binary input sensor to gw (they will be created as child devices)
// You can use S_DOOR, S_MOTION or S_LIGHT here depending on your usage.
// If S_LIGHT is used, remember to update variable type you send in. See "msg" above.
present(CHILD_ID, S_DOOR);
// Check if digital input has changed and send in new value
void loop()
debouncer.update();
// Get the update value
int value = debouncer.read();
Serial.println(value);
if (value != oldValue) {
// Send in the new value
send(msg.set(value==HIGH ? 1 : 0));
oldValue = value;
digitalWrite(13,value);
;255;3;0;9;TSF:MSG:BC
0;255;3;0;9;TSF:MSG:FPAR REQ,ID=6
0;255;3;0;9;TSF:PNG:SEND,TO=0
0;255;3;0;9;TSF:CKU:OK
0;255;3;0;9;TSF:MSG:GWL OK
0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
..0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
0;255;3;0;9;TSF:MSG:PINGED,ID=6,HP=1
0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
....0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=0,t=0,pt=0,l=0,sg=0:
0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
0;255;3;0;9;TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
0;255;3;0;9;TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=2,l=2,sg=0:1
.........................................0;255;3;0;9;TSF:SRT:OK
0;255;3;0;9;TSF:SAN:OK
.......................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................0;255;3;0;9;TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
0;255;3;0;9;TSF:MSG:BC
................................................................................................................................................................................................0;255;3;0;9;TSM:READY:NWD REQ
0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
...0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
..........................................................................................................................................................................................................................0;255;3;0;9;TSF:SAN:OK
.......................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................0;255;3;0;9;TSM:READY:NWD REQ
........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................0;255;3;0;9;TSF:SAN:OK
.0;255;3;0;9;TSF:MSG:READ,6-6-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................0;255;3;0;9;TSF:SRT:OK
Switch Node output
60 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.2.0-beta
4 TSM:INIT
4 TSF:WUR:MS=0
11 TSM:INIT:TSP OK
13 TSF:SID:OK,ID=6
15 TSM:FPAR
51 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
309 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
314 TSF:MSG:FPAR OK,ID=0,D=1
2058 TSM:FPAR:OK
2059 TSM:ID
2060 TSM:ID:OK
2062 TSM:UPL
2065 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
2173 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
2178 TSF:MSG:PONG RECV,HP=1
2181 TSM:UPL:OK
2182 TSM:READY:ID=6,PAR=0,DIS=1
2187 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
2320 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
2327 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
2336 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
4343 TSF:MSG:SEND,6-6-0-0,s=3,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
4349 MCO:REG:REQ
4353 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
4473 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
4478 MCO:PIM:NODE REG=1
4481 MCO:BGN:STP
