Orcon Mechanical Ventilator MVS15 - 868 MHz
Posted: Tuesday 28 March 2017 10:31
Does anyone have some experience connecting a Orcon Mechanical Ventilator MVS15 to Domoticz?
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
"Invalid data received!...."Code: Select all
13/05/2024 06:10:58:911= Get Status
13/05/2024 06:10:58:960= 140100030255170000002003031C15720000240000
Packettype = Interface Message
subtype = Interface Response
Sequence nbr = 3
response on cmnd = Get Status
Transceiver type = 868MHz
Firmware version = 1023
Firmware Type = RFX868
Noise level = -114 dBm
Transmit power = 10dBm
Hardware version = 3.3 RFX433/RFX868/RFXtrx868XL
Debug off
Alecto ACH2010 disabled
FineOffset disabled
La Crosse disabled
Davis EU disabled
Davis US disabled
Davis AU disabled
GAPOSA disabled
FS20 disabled
LightwaveRF disabled
Edisio disabled
Visonic disabled
Meiantech disabled
Proguard disabled
Itho CVE RFT disabled
Itho CVE,HRU ECO disabled
Orcon enabled
Itho CVE-S,HRU400 disabled
Honeywell Chime disabled
KeeLoq disabled
13/05/2024 06:21:21:523= 11170C007724731120772473000000BF0000
Packettype = FAN2
subtype = Orcon
Sequence nbr = 0
ID = 772473 decimal:7808115
Destination ID= 772473 decimal:7808115
Command = Fan speed:00 = Off
Filter?? :00 = Filter OK
Signal level = 2 -104dBm
13/05/2024 06:21:43:163= 11170C0176A9270730772473000000000000
Packettype = FAN2
subtype = Orcon
Sequence nbr = 1
ID = 76A927 decimal:7776551
Command = Auto
Signal level = 3 -96dBm
13/05/2024 06:21:43:602= 11170C027724731130772473000004BB0000
Packettype = FAN2
subtype = Orcon
Sequence nbr = 2
Command = Fan speed:04 = Auto
13/05/2024 06:22:05:511= 11170C037724731120772473000003BC0000
Packettype = FAN2
subtype = Orcon
Sequence nbr = 3
Command = Fan speed:03 = High
13/05/2024 06:22:22:809= 11170C0476A9270130772473000000000000
Packettype = FAN2
subtype = Orcon
Sequence nbr = 4
Command = Low
13/05/2024 06:22:23:569= 11170C057724731130772473000001BE0000
Packettype = FAN2
subtype = Orcon
Sequence nbr = 5
Command = Fan speed:01 = Low
13/05/2024 06:22:49:553= 11170C0676A9270230772473000000000000
Packettype = FAN2
subtype = Orcon
Sequence nbr = 6
Command = Medium
13/05/2024 06:22:50:542= 11170C077724731140772473000002BD0000
Packettype = FAN2
subtype = Orcon
Sequence nbr = 7
Command = Fan speed:02 = Medium
Signal level = 4 -88dBm
13/05/2024 06:22:58:117= 11170C0876A9270330772473000000000000
Packettype = FAN2
subtype = Orcon
Sequence nbr = 8
Command = High
13/05/2024 06:22:58:554= 11170C097724731120772473000003BC0000
Packettype = FAN2
subtype = Orcon
Sequence nbr = 9
Signal level = 2 -104dBmDid you find a solution or alter the code and extend the integration ?opechunka wrote: Sunday 24 November 2024 16:05 Also tried with RFXtrx. Received "Invalid data received!....".
But even after I changed the source code and commented out check for type pTypeFan, Domoticz detected new buttons per every Orcon button (if you press it). But they were not functional at all. While looking into Domoticz source code for Orcon support, it looks like the imlementation is not finished.
