nRF24L01 and RFLink from Nodo-shop
Posted: Sunday 26 March 2017 17:11
by quack3d
If I understand correctly, I can get a nRF24L01 for a few bucks that slots right into my RFLink gateway I got from Nodo-shop without any soldering, and then be able to control Milight bulbs and LED strips.
However, I see there is the normal nRF24L01 and the high power one with antenna. And according to the following page the Arduino Mega doesn't provide enough power for the antenna version:
https://arduino-info.wikispaces.com/Nrf ... 4GHz-HowTo
Have I understood that correctly? If so, perhaps the Wiki for RFLink should have this information.
Re: nRF24L01 and RFLink from Nodo-shop
Posted: Sunday 26 March 2017 17:30
by Stuntteam
quack3d wrote:If I understand correctly, I can get a nRF24L01 for a few bucks that slots right into my RFLink gateway I got from Nodo-shop without any soldering, and then be able to control Milight bulbs and LED strips.
Correct.
I have tried the high power NRF on the nodo pcb and it works without any problems.
Posted: Tuesday 28 March 2017 20:50
by quack3d
Brilliant. Thanks a bunch. On its way.
Posted: Tuesday 18 April 2017 11:12
by quack3d
So I attached the NRF24L01 to the RFLink, ran RFLink Loader V1.10 on the right serial port and enabled MiLight. Starting Serial Port Logging now says:
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R46;
20;01;MiLight=ON;
20;02;setGPIO=ON;
10;version;
20;03;VER=1.1;REV=46;BUILD=0c;
10;status;
20;04;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=ON;setLivingColors=OFF;setAnsluta=OFF;setGPIO=ON;setBLE=OFF;setMysensors=OFF;
However, if I click any button on my MiLight remote, nothing is logged in RFLink Loader. What could be wrong?
Posted: Friday 21 April 2017 20:01
by quack3d
Could the lack of signals from my MiLight remote indicate not enough power? Or perhaps something else is wrong?
Posted: Saturday 22 April 2017 0:14
by Stuntteam
probably something else is wrong
Posted: Saturday 22 April 2017 0:19
by quack3d
Stuntteam wrote:probably something else is wrong
I created a thread here:
https://www.letscontrolit.com/forum/vie ... =11&t=2967
I assume that's more appropriate.
Posted: Saturday 22 April 2017 13:55
by sincze
Stuntteam wrote:quack3d wrote:If I understand correctly, I can get a nRF24L01 for a few bucks that slots right into my RFLink gateway I got from Nodo-shop without any soldering, and then be able to control Milight bulbs and LED strips.
Correct.
A nice that feature I did not know.
I had to wire a separate nrf antenna for milight back in the days if I remember correctly as the slot on the pcb was used for NoDo only if I remember correclty.
So I guess I misread the release notes
http://www.nemcon.nl/blog2/faq#Freq3
A: That depends on the Nodo PCB version.
Version 1.1.3 and higher: Yes.
As an early adopter... It seems I can't ,however with a separate antenna it works just fine.
