After the last update of domotics my relay-board stopped working, the Temperature from the same node i still working. This is the log printout
2017-03-24 20:30:21.347 (RFLink) Temp (Mebus)
2017-03-24 20:30:27.433 (Mysensor) Temp + Humidity (TempHum_in_IROXbox_Källare)
2017-03-24 20:30:32.530 MySensors: Node: 16, Sketch Name: My Relayboard_16 This is my relaynode
2017-03-24 20:30:39.875 (RFLink) Temp + Humidity (Väderstation temp2 Garage)
2017-03-24 20:31:07.216 (RFLink) Temp (FineOffset2)
2017-03-24 20:31:07.422 (RFLink) Temp (FineOffset2)
2017-03-24 20:31:07.622 (RFLink) Temp (FineOffset2)
2017-03-24 20:31:07.827 (RFLink) Temp (FineOffset2)
2017-03-24 20:31:08.080 (Mysensor) Temp (Golvvaerme inlopp Temp)
2017-03-24 20:31:14.438 User: Admin initiated a switch command (633/Realy 16 Light/On) This is where error happens
2017-03-24 20:31:14.439 Error: MySensors: Unknown action received Mysensors dont understand this any more
2017-03-24 20:31:17.389 (RFLink) Wind (Väderstation Vind)
2017-03-24 20:31:23.262 (RFLink) Temp + Humidity (VP Källare Temp)
2017-03-24 20:31:24.380 (Mysensor) Temp (Stairs Repeater and Temp)
2017-03-24 20:31:25.015 (RFLink) Temp + Humidity (Väderstation temp2 Garage)
2017-03-24 20:31:30.290 (Mysensor) Temp (Relay 16 Temp) This tempmessage from relay node is OK
2017-03-24 20:31:30.532 (RFLink) Temp (Mebus)
Any ideas where the problem can be?
No contact with relay board after update!
mcmacpl
Re: No contact with relay board after update!
After some recent updates, domoticz changed type of mysensors light switches.
I had the same situation, and had to restart all nodes and replace previous devices with new recognized devices.
Now they are of type Light/Switch, not Lightning 2.
ollebull
That worked for me as well, thanks for the tip.
All nodes now restarted and work again after some fiddling with the names in domoticz
I guess we can close this topic now.
Regards OlleBull
Regards OlleBull
