My dzVents Wind Monitoring script
Posted: Thursday 23 March 2017 8:21
Hey guys.
I'd like to share my dzVents Wind Monitoring script.
The idea is to provide info about the strongest seen wind gust level for the last 30 minutes and display it in an Alert Device.
I have a wind speed meter (WIND_DEVICE) that is reporting the wind speed to Domoticz regularly. (It might not report if the wind conditions haven't changed since last time) The virtual Domoticz Alert Device will display the current wind conditions and an alert level allowing to automate tasks like the automatic retraction of my window awnings etc.
EDIT: Updated the script to version 1.0.1
windMonitoring.lua by BakSeeDaa
Version 1.0.2
local WIND_DATA_MAX_AGE = 30
local ALERT_SENSOR = 'Wind Alert'
local WIND_DEVICE = 'WH2600 Wind'
local WIND_HURRICANE_TEXT = 'Orkan. Mer än 32,7 m/s'
local WIND_VIOLENT_STORM_TEXT = 'Svår storm. 28,5–32,6 m/s'
local WIND_STORM_TEXT = 'Storm. 24,5–28,4 m/s'
local WIND_STRONG_GALE_TEXT = 'Halv storm. 20,8–24,4 m/s'
local WIND_FRESH_GALE_TEXT = 'Hård kuling. 17,2–20,7 m/s'
local WIND_MODERATE_GALE_TEXT = 'Styv kuling. 13,9–17,1 m/s'
local WIND_STRONG_BREEZE_TEXT = 'Hård bris. 10,8–13,8 m/s'
local WIND_FRESH_BREEZE_TEXT = 'Styv bris. 8,0–10,7 m/s'
local WIND_MODERATE_BREEZE_TEXT = 'Frisk bris. 5,5–7,9 m/s'
local WIND_GENTLE_BREEZE_TEXT = 'God bris. 3,4–5,4 m/s'
local WIND_CALM_TO_LIGHT_BREEZE_TEXT = 'Stiltje till lätt bris. 0–3,3 m/s'
local WIND_HURRICANE_LEVEL = 32.7
local WIND_VIOLENT_STORM_LEVEL = 28.5
local WIND_STORM_LEVEL = 24.5
local WIND_STRONG_GALE_LEVEL = 20.8
local WIND_FRESH_GALE_LEVEL = 17.2
local WIND_MODERATE_GALE_LEVEL = 13.9
local WIND_STRONG_BREEZE_LEVEL = 10.8
local WIND_FRESH_BREEZE_LEVEL = 8
local WIND_MODERATE_BREEZE_LEVEL = 5.5
local WIND_GENTLE_BREEZE_LEVEL = 3.4
active = true,
WIND_DEVICE,
['timer'] = 'every minute'
data = {
lastSeenHurricane = { history = true, maxItems = 1 },
lastSeenViolentStorm = { history = true, maxItems = 1 },
lastSeenStorm = { history = true, maxItems = 1 },
lastSeenStrongGale = { history = true, maxItems = 1 },
lastSeenFreshGale = { history = true, maxItems = 1 },
lastSeenModerateGale = { history = true, maxItems = 1 },
lastSeenStrongBreeze = { history = true, maxItems = 1 },
lastSeenFreshBreeze = { history = true, maxItems = 1 },
lastSeenModerateBreeze = { history = true, maxItems = 1 },
lastSeenGentleBreeze = { history = true, maxItems = 1 }
execute = function(domoticz, windDevice, triggerInfo)
local LOG_LEVEL = domoticz.LOG_DEBUG -- Script default log level. You may change this.
if (triggerInfo.type == domoticz.EVENT_TYPE_TIMER) then
-- Timer event occurred
-- Init data if missing (e.g. the first time that the scripts runs)
-- Note that all wind speeds initially will have the current time as "Last Seen", it will cause an alert.
if (domoticz.data['lastSeenHurricane'].size == 0) then domoticz.data['lastSeenHurricane'].add('Init') end
if (domoticz.data['lastSeenViolentStorm'].size == 0) then domoticz.data['lastSeenViolentStorm'].add('Init') end
if (domoticz.data['lastSeenStorm'].size == 0) then domoticz.data['lastSeenStorm'].add('Init') end
if (domoticz.data['lastSeenStrongGale'].size == 0) then domoticz.data['lastSeenStrongGale'].add('Init') end
if (domoticz.data['lastSeenFreshGale'].size == 0) then domoticz.data['lastSeenFreshGale'].add('Init') end
if (domoticz.data['lastSeenModerateGale'].size == 0) then domoticz.data['lastSeenModerateGale'].add('Init') end
if (domoticz.data['lastSeenStrongBreeze'].size == 0) then domoticz.data['lastSeenStrongBreeze'].add('Init') end
if (domoticz.data['lastSeenFreshBreeze'].size == 0) then domoticz.data['lastSeenFreshBreeze'].add('Init') end
if (domoticz.data['lastSeenModerateBreeze'].size == 0) then domoticz.data['lastSeenModerateBreeze'].add('Init') end
if (domoticz.data['lastSeenGentleBreeze'].size == 0) then domoticz.data['lastSeenGentleBreeze'].add('Init') end
-- Update the Wind Alert virtual sensor
local alertLevel = domoticz.ALERTLEVEL_GREY
local alertText = WIND_CALM_TO_LIGHT_BREEZE_TEXT
local alertSensor = domoticz.devices[ALERT_SENSOR]
if (domoticz.data['lastSeenHurricane'].getLatest().time.minutesAgo < WIND_DATA_MAX_AGE) then
alertLevel = domoticz.ALERTLEVEL_RED
alertText = WIND_HURRICANE_TEXT
elseif (domoticz.data['lastSeenViolentStorm'].getLatest().time.minutesAgo < WIND_DATA_MAX_AGE) then
alertText = WIND_VIOLENT_STORM_TEXT
elseif (domoticz.data['lastSeenStorm'].getLatest().time.minutesAgo < WIND_DATA_MAX_AGE) then
alertText = WIND_STORM_TEXT
elseif (domoticz.data['lastSeenStrongGale'].getLatest().time.minutesAgo < WIND_DATA_MAX_AGE) then
alertLevel = domoticz.ALERTLEVEL_ORANGE
alertText = WIND_STRONG_GALE_TEXT
elseif (domoticz.data['lastSeenFreshGale'].getLatest().time.minutesAgo < WIND_DATA_MAX_AGE) then
alertText = WIND_FRESH_GALE_TEXT
elseif (domoticz.data['lastSeenModerateGale'].getLatest().time.minutesAgo < WIND_DATA_MAX_AGE) then
alertLevel = domoticz.ALERTLEVEL_YELLOW
alertText = WIND_MODERATE_GALE_TEXT
elseif (domoticz.data['lastSeenStrongBreeze'].getLatest().time.minutesAgo < WIND_DATA_MAX_AGE) then
alertText = WIND_STRONG_BREEZE_TEXT
elseif (domoticz.data['lastSeenFreshBreeze'].getLatest().time.minutesAgo < WIND_DATA_MAX_AGE) then
alertLevel = domoticz.ALERTLEVEL_GREEN
alertText = WIND_FRESH_BREEZE_TEXT
elseif (domoticz.data['lastSeenModerateBreeze'].getLatest().time.minutesAgo < WIND_DATA_MAX_AGE) then
alertText = WIND_MODERATE_BREEZE_TEXT
elseif (domoticz.data['lastSeenGentleBreeze'].getLatest().time.minutesAgo < WIND_DATA_MAX_AGE) then
alertText = WIND_GENTLE_BREEZE_TEXT
domoticz.log('alertSensor.rawData[1]: '..alertSensor.rawData[1], LOG_LEVEL)
domoticz.log('alertText: '..alertText, LOG_LEVEL)
if(alertSensor.rawData[1] ~= alertText) then
alertSensor.updateAlertSensor(alertLevel, alertText)
-- Device event occurred
local sWindDirectionDegrees = tonumber(windDevice.rawData[1])
local sWindDirection = windDevice.rawData[2]
local sWindSpeed = tonumber(windDevice.rawData[3]) * 0.1
local sWindGust = tonumber(windDevice.rawData[4]) * 0.1
local sWindTemperature = tonumber(windDevice.rawData[5])
local sWindChill = tonumber(windDevice.rawData[6])
domoticz.log('______________________________________________________________________________________', LOG_LEVEL)
domoticz.log('Windmeter: Winddirection (in degrees) is: '..sWindDirectionDegrees, LOG_LEVEL)
domoticz.log('Windmeter: Winddirection is: '..sWindDirection, LOG_LEVEL)
domoticz.log('Windmeter: Windspeed is: '..sWindSpeed, LOG_LEVEL)
domoticz.log('Windmeter: Windgust is: '..sWindGust, LOG_LEVEL)
domoticz.log('Windmeter: Windtemperature is: '..sWindTemperature, LOG_LEVEL)
domoticz.log('Windmeter: Windchill is: '..sWindChill, LOG_LEVEL)
if (sWindGust >= WIND_GENTLE_BREEZE_LEVEL) then domoticz.data['lastSeenGentleBreeze'].add() end
if (sWindGust >= WIND_MODERATE_BREEZE_LEVEL) then domoticz.data['lastSeenModerateBreeze'].add() end
if (sWindGust >= WIND_FRESH_BREEZE_LEVEL) then domoticz.data['lastSeenFreshBreeze'].add() end
if (sWindGust >= WIND_STRONG_BREEZE_LEVEL) then domoticz.data['lastSeenStrongBreeze'].add() end
if (sWindGust >= WIND_MODERATE_GALE_LEVEL) then domoticz.data['lastSeenModerateGale'].add() end
if (sWindGust >= WIND_FRESH_GALE_LEVEL) then domoticz.data['lastSeenFreshGale'].add() end
if (sWindGust >= WIND_STRONG_GALE_LEVEL) then domoticz.data['lastSeenStrongGale'].add() end
if (sWindGust >= WIND_STORM_LEVEL) then domoticz.data['lastSeenStorm'].add() end
if (sWindGust >= WIND_VIOLENT_STORM_LEVEL) then domoticz.data['lastSeenViolentStorm'].add() end
if (sWindGust >= WIND_HURRICANE_LEVEL) then domoticz.data['lastSeenHurricane'].add() end
