4 chanel relay
Posted: Wednesday 22 March 2017 8:33
hello,
i ordered this RF 4 chanel relay without remote
It has one button for code learning, and jumper for changing modes (i use Latched mode)
https://www.aliexpress.com/item/DK-4TC- ... 0.0.GNeW9t
I want to use it for my irrigation system, i have allready conected (only with leds for test) and it works quite good..
problem is that when i learn code, both codes (on and off) are toggle so sometimes i have inverted states in domoticz switch panel and its not secure for irrigation
Anyone know how to setup to make off code, really off and not just toggle?
Ali is full of these kind of rellays and woud be great to full support in RFLink.
edit:
i used some default chuango codes manually added with create RFlink command. (on/off works but both commands are toggle)
Discovered that also Aoke type and as HW my RFLink works. (but it' switches only to On the relay, but the switch on the Domoticz panel remain in Off status.)
edit:
