I am new here.
I have bought 2 Home Easy HE877 units.
I try too couple this units in Domoticz with RFlink at my Raspberry Pi.
But without success.
I add manually the HE877
Hardware: RFlink
Apparaat naam: Lamp
Schakelaar type: ON/OFF
Type: HE EU
ID: 1 06 11 40
Unit Code: 1
I pressure on the learn button of the HE877 and then next on the button "testen" in Domoticz.
I add the lamp in Domoticz. But when I pressure on the "lamp" in Domoticz, nothings happens. The lamp switch not from white too yellow.
In the logfile of Domoticz I see the next:
2017-03-21 20:03:55.158 User: Admin initiated a switch command (51/test/On)
2017-03-21 20:03:55.159 RFLink Sending: 10;HomeEasy;71061140;1;ON
What I do wrong?
Jack
Home Easy don't work
- Stuntteam
Re: Home Easy don't work
Wrong method.
Go to settings, hardware
press the "create rflink device" button.
In the popup enter:
20;04;FA500;ID=00001287;SWITCH=01;CMD=ON;
go to the devices page, add device with the green arrow..
put the unit in learning mode and press on
In the popup enter:
jack100
This week I will try.
I have also an Quigg GT-FSI-05 click on click off set (4 pieces)
What is the code for this set?
20;04;?;SWITCH=01;CMD=ON;??
Jack
Jack
- Stuntteam
Use the remote.. rflink will detect the signal and add it to the device list..
jack100
For the Home Easy HE877 unit.
I do the next:
In the popup enter:
Put the unit in the learning mode. How?
Manualy or with the control unit?
I have only buy the HE877 unit without control unit.
When I put the unit HE877 in the learning mode and press on (the lamp icon go to yellow), nothing happens.
Jack
I do the next:
In the popup enter:
Jack
jack100
The Quigg GT-FSI-05 click on click off set works!
Jack
Jack
