Alarm Trigger Event via LUA (solved) Topic is solved
roy1982hd
Post by roy1982hd »
Hi everybody,
My LUA-intruder-alarm-event seems to contain a small mistake.
Protocol says:
Error: EventSystem: in Alarmfall Einbruch: [string "commandArray = {} ..."]:4: ')' expected near '='
Here's the event-code:
 if (devicechanged['FensterOderTuerOffen']) then
        if (otherdevices['FensterOderTuerOffen'] == 'On') then
                if (otherdevices['Domoticz Security Panel'] = 'Arm Away') then
                    commandArray['Group:Alarmmelder']='On FOR 60'
                    print('Einbruch! Alarmmelder angeschaltet für 60 Minuten!')
                elseif (otherdevices['Domoticz Security Panel'] = 'Disarm') then
                    print('Tür oder Fenster wurde geöffnet')
                print('Alle Türen und Fenster geschlossen')
Can anyone help me to find the mistake? Where is the bracket missing?
Thanks in advance!
jvdz
Domoticz version: 4.107
Re: Alarm Trigger Event via LUA / Can't find the mistake
Post by jvdz »
should be
if (otherdevices['Domoticz Security Panel'] == 'Arm Away') then
and
should be
elseif (otherdevices['Domoticz Security Panel'] == 'Disarm') then
Jos
roy1982hd
Post by roy1982hd »
Thank you very much, Jos!
Just tested it and the alarm-event works now!
I) ALARM TRIGGER EVENT
1) FensterOderTuerOffen' = is a virtual device that is a parent switch of all door and window-sensors
2) 'Alarmmelder' = is a group that controls all sirens/smoke detectors
Code:
II) Zipato RFID Keypad EVENT
With a second event I control the actions of a Zipato RFID Keypad.
If the Zipato is switched to "Away", the Security Panel is switched to "Arm Away" and two Zipato RGBW bulbs (one inside and one outside of the front door of our house) give an orange light ... like a security status LED.
If the Zipato is switched to "Home", the Security Panel is switched to "Disarm" and the bulbs light in green colour and then switch off after some seconds.
Code:
 if (devicechanged['Keypad']) then
        if (otherdevices['Keypad'] == 'On') then
                print('AlarmPanel Arm Away')
                commandArray['Domoticz Security Panel'] = 'Arm Away'
                commandArray['Group:Alarmstatuslampen orange']='On'
                print('AlarmPanel Disarm')
                commandArray['Domoticz Security Panel'] = 'Disarm'
                commandArray['Group:Alarmmelder']='Off'
                commandArray['Group:Alarmstatuslampen grün']='On'
                commandArray['Alarmstatuslampe innen']='Off AFTER 10'
                commandArray['Alarmstatuslampe außen']='Off AFTER 10'
