Vision 2102 => Wrong information in OpenZWave Control Panel
Posted: Thursday 16 March 2017 16:33
I have six Vision EU 2102 door/window sensors. I had them included to the ZWave.Me Raspberry GPIO board using the ZWay software. (RPi 3)
When switching to Domoticz 3.6953 I excluded one of them and then included it again. (I've done this three times with identical results)
The device gets excluded and included just fine. The problem is that I can't get the device to recognise shifting in status (opening and closing door)
The Log shows that all the other devices (alarms ..) belonging to this sensor actually changes, but the main one, the sensor itself, always stays in status "on".
When I examined the controller configuration file, I noticed that there is a difference between the entries for this sensor and the rest (that works). When looking at OpenZWave - Control Panel, the difference is that the one that works has a "Generic Type" of Routing Binary Sensor but the one that doesn't work is listed as Routing Slave.
Has anyone else tried including a Vision 2102 sensor with correct results?
Is there a way to change this value manually?
br J
ps -- LOG ENTRY
// this one is from the one that doesn't work (the "X-" is just to find it in log
// Note that there is only ten records but on working there is twelve (open+close)
2017-03-16 16:41:36.943 (Zwave.Me) Light/Switch (X- Alarm Type)
2017-03-16 16:41:36.946 (Zwave.Me) Lighting 2 (Alarm Type: 0x07)
2017-03-16 16:41:36.948 (Zwave.Me) Light/Switch (X- Alarm Level)
2017-03-16 16:41:36.950 (Zwave.Me) General/Alarm (X- Alarm Type: Burglar 7 (0x07) )
2017-03-16 16:41:36.951 (Zwave.Me) Light/Switch (X- Burglar)
2017-03-16 16:41:52.947 (Zwave.Me) Light/Switch (X- Alarm Type)
2017-03-16 16:41:52.951 (Zwave.Me) Lighting 2 (Alarm Type: 0x07)
2017-03-16 16:41:52.953 (Zwave.Me) Light/Switch (X- Alarm Level)
2017-03-16 16:41:52.955 (Zwave.Me) General/Alarm (X- Alarm Type: Burglar 7 (0x07) )
2017-03-16 16:41:52.956 (Zwave.Me) Light/Switch (X- Burglar)
// this is from working sensor (open+close)
2017-03-16 16:44:20.304 (Zwave.Me) Light/Switch (Door 1) // this is missing above
2017-03-16 16:44:20.323 (Zwave.Me) Light/Switch (Alarm Type)
2017-03-16 16:44:20.325 (Zwave.Me) Lighting 2 (Alarm Type: 0x07)
2017-03-16 16:44:20.327 (Zwave.Me) Light/Switch (Alarm Level)
2017-03-16 16:44:20.330 (Zwave.Me) General/Alarm (Alarm Type: Burglar 7 (0x07))
2017-03-16 16:44:20.331 (Zwave.Me) Light/Switch (Burglar)
2017-03-16 16:44:26.100 (Zwave.Me) Light/Switch (Door 1) // this is missing above
2017-03-16 16:44:26.119 (Zwave.Me) Light/Switch (Alarm Type)
2017-03-16 16:44:26.122 (Zwave.Me) Lighting 2 (Alarm Type: 0x07)
2017-03-16 16:44:26.124 (Zwave.Me) Light/Switch (Alarm Level)
2017-03-16 16:44:26.126 (Zwave.Me) General/Alarm (Alarm Type: Burglar 7 (0x07))
2017-03-16 16:44:26.127 (Zwave.Me) Light/Switch (Burglar)
br J
ps -- LOG ENTRY
