New module - BleBox
fantom
New module - BleBox
Recently I wrote a module to support BleBox devices
http://www.blebox.eu
If anyone has any comments, questions etc that invite i wait for Your question.
regards
Fantom
regards
Fantom
szymi
Re: New module - BleBox
Hi, great work, thanks for publishing this plug-in. Have you considered using milliseconds as parameter of movement for ShutterBox instead of percentage? Percentage is fine for shutters, however it is not precise enough for blinds. For blinds, the movement is a little more complicated, it should be possible to tilt them. For instance in my case, starting from 0% position, blinds take about 60 seconds to move down. Then, I move them up for 0.8 second (however, it could be 0.9 seconds on a very sunny day or in the eventing, or it could be 1 second on a cooler day). The movement up is needed for the blinds to tilt. This is the most simple case for blinds, it could get way more complicated, to complicate to explain here. However it would be very useful if even just this simplest case was implemented in your plug-in. At home, I use some python scripts that I wrote myself to control my blinds. The scripts do the job very well, however they lack GUI and also probably will need to be maintained in the future - and this is going to be a pain. I would love to switch control of my blinds to Domoticz, however I cannot do it at this time - at least not until I find some solution to this problem. Going down to 100% and then up to 99% does not solve the problem, because for some strange reason 99% is quite high up. I do not know C and probably will not find time to learn it just for this purpose. I will try, but probably will not achieve much. Even if I do, it will probably not pass code review on Github
szymi
szymi
wroled
I invite you to our channel on Youtube.
We present blebox modules, installation method, synchronization with Domoticz, connection to various devices - LED lighting, etc.
https://www.youtube.com/channel/UC1fzwA ... 1QXzDNBCCQ and our online store www.wroled.pl/blebox
fantom
A few days ago i pushed new changes (also with shutterBox)
Fantom
Fantom
corederoma82
Hi, where is possible to find this module?fantom wrote: Wednesday 15 March 2017 21:44 Hi
regards
Fantom
Is it functioning with blebox temperature sensor?
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
fantom
Domoticz->Hardware->BleBox
tempSensor is not fully supported. I will end implementation on nearest days.
Fantom
Fantom
corederoma82
Ok, thanks for your reply.fantom wrote: Thursday 16 May 2019 18:37 Domoticz->Hardware->BleBox
Fantom
For now, which devices are supported?
fantom
All, but tempSensor and airSensor implementation is not ended.
Fantom
Fantom
corederoma82
Ok, thanks again for your reply.
I wait for Tempsensor.
Galubson
I have a problem with adding a new BleBox device in to the domoticz. When i click Auto Search, nothing happened and my domoticz goes down. Earlier i succesfuly added 4 devices, now I wanna to add 3 new but i can't :/ Can someone help?
fantom
I see thay auto-search have a problem sometimes (stopped domoticz).
I try resolve this issue
Fantom
Fantom
mastadook
- Domoticz version: 2022.1
Hi Fantom,
I have a Problem with this Module.
I´m using this Domoticz Version:
Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
I have added the Module to my Hardware, try to search, nothing happens.
Try to save Settings: Error Message: Problems saving the Settings
Domoticz crashes, no Hardware Device to find, Restart Domoticz by restartscript, Domoticz is working again
but when I try the Steps again, it did not work.
May this is what you Describe above, but:
Try to manual add the Device -- Error Message: Problems adding the Device
No Chance to get it running right now
Any Idea? Best Regards
Version: 4.10717
________________________________________________________________________
global chief of permanent lightning and strike detonator
fantom
Only one idea: please install beta version of domoticz.
Version from 05.2019 is very old.
I did many changes since then version.
Fantom
Fantom
mastadook
hmm, still not possible to add new Devices.
Autosearch crashes Domoticz and Add Device did not work, now with no Error Message.
2019-09-05 11:37:56.487 Status: BleBox: Worker started...
2019-09-05 11:37:56.487 Error: BleBox: Cannot find any devices...
when I try to add manually, i see in Protocoll:
2019-09-05 11:45:42.397 Error: BleBox: Cannot find any devices...
But it has this IP and Name, something went wrong somewhere
fantom
Add device manually.
Did You enabled adding new devices in settings ?
Fantom
Fantom
mastadook
Great, thank you, this worked now.fantom wrote: Thursday 05 September 2019 13:20 Add device manually.
Fantom
Now, it is interesting:
If I set with old Fibaro Shutter to 80% it nearly closed.
If I set with BleBox it is nearly open, but up and down goes in the correkt direction...
It´s so crazy, I like to trow the Fibaros away cause of Ghostswitching and Blebox also doing crazx things
fantom
Did You run auto calibration on shutter box ?
mastadook
yes, off course.
If I set to 80% it is nearly full open, if I change the Output for example,
then if I move the dot complete to the right side, ist stops at about 80%.
Domoticz says 100% closed but it ia not closed...
mastadook
here, with a Pictuce you see what mean.
the first one is the BleBox and wrong, the second one with Zwave is ok.
up and down goes in correct directions when clicking on the Arrows...
it makes no difference if I choose "blinds" or "blinds inverted"
- rolladen.PNG (36.7 KiB) Viewed 6723 times
Last edited by mastadook on Monday 09 September 2019 8:29, edited 1 time in total.
fantom
BleBox is configurable.
You may change direction, switches etc in config by the web or wBox app.
In domoticz, try maybe change switch type from "inverted" to normal.
