Fibaro Double Switch FGS-223 only switches with physical toggle switch
Posted: Wednesday 15 March 2017 9:44
by meijerpeter
I have several Fibaro z-wave devices around the house in combination with Domoticz on a RPi3. The majority is installed with a momentary switch in combination with a dimmer module.
My issue is that I cannot switch S1 with Domoticz, only with the (single) toggle switch. S2 can be switched with Domoticz, but I have no physical switch attached to Q2/S2. Parameter 20 is on '2', I have also tried '1'.
Does anyone know if I have to set another parameter to enable the switching from within Domoticz??
Many thanks!
Re: Fibaro Double Switch FGS-223 only switches with physical toggle switch
Posted: Thursday 16 March 2017 12:18
by pvdhelm
reboot your domoticz server and it wil work. Had the same issue
Posted: Tuesday 21 March 2017 7:34
by meijerpeter
Worked! Many thanks!!
Posted: Sunday 09 April 2017 12:33
by FriedlNet
It works for me very well too. Many thanks!!
Posted: Sunday 16 April 2017 1:00
by berny
I spend hours to resolve this problem after include FGS-223
S1(switch on/off) / Q1(on/off) => OK
S2(switch on/off) / Q2(on/off) => OK
via domoticz:
S1(domoticz on/off) / Q1(on/off) => NOT OK!!!
S2(domoticz on/off) / Q2(on/off) => OK
when I have read this subject and
I have REBOOT my Raspberry => everything OK!!!
Thanks for this hint.
But why ??
Posted: Tuesday 23 May 2017 10:15
by Olfer
Also worked for me! Thanks a lot for this hint!
Posted: Tuesday 14 November 2017 20:02
by robpow
Can’t believe it was that easy! Had the exact same problem.
Matt
Posted: Wednesday 15 November 2017 12:04
by Abelphoenix
I have the same problem Q1 does not change state with domoticz. in windows it does not work restarting the system. Any solution please?
Posted: Wednesday 27 December 2017 22:41
by Kazaa2978
This worked for me also!
Edit ... Below also solved after next reboot next day
Almost......
Now both the Switches work again within Domoticz but still only one will react from my Homekit
In the beginning the S1 did not react by Domoticz and not by the app (S2 works perfectly)
But now S1 works from Domoticz but domoticz still does not react on Homekit(homebridge) push button
I have all the parameters the same between S1 and S2.
Anybody an idea, or how to see if homebridge actualy sends a signal to Domoticz?
Posted: Saturday 27 January 2018 14:32
by chang
Rebooting via shell script worked for me too on Ubuntu.
Posted: Monday 05 March 2018 2:50
by Abelphoenix
in windows no found...
Posted: Sunday 26 August 2018 14:20
by Prog
pvdhelm wrote: Thursday 16 March 2017 12:18
Sorry to resurrect this thread but I just wanted to thank you. Your post saved me a lot of stress.
Posted: Friday 08 February 2019 21:30
by JacKok
Thanks, you save my day!!
