Fibaro RGBW controller - RGB strip + analog temperature sensor
Posted: Tuesday 14 March 2017 23:25
by morscerta
Hi.
I have a Fibaro RGBW module that I connected to a RGB strip (note that there is no +W). I use a Raspberry Pi + Domoticz + Aeon Z-Wave Stick as a controller. Everything worked fine. Then I connected an analog temperature sensor LM35DZ that outputs 0-10V, so theoretically should work well with RGBW module. I attach a scheme of how I connected the modules.
Fibaro RGB Temp.png (9.81 KiB) Viewed 1200 times
RGB color-changing functionality still works, however I seemingly can't figure out how to read a temperature/voltage from the sensor. I understand that the trick is in properly defining a parameter 14. I tried a number of different versions of parameter 14 that I found on the Internet or deduced myself. I can't get anything to work, including 39320 which I think should be the correct one (1001-1001-1001-1000, all normal monostable out, in4 analog in).
I don't need any switches, I want to operate RGB through a Domoticz only. Is it possible to operate an RGB strip at the same time with analog 0-10V sensor? How should I connect and configure the node? What parameter 14 should be like?
Thanks in advance,
m.
Re: Fibaro RGBW controller - RGB strip + analog temperature sensor
Posted: Tuesday 13 February 2018 5:07
by TheDane
Hi.
Did you find a solution regarding the temp sensor?
Does it work ok with the rgwb module, maybe without the strip?
I'm asking because I would like to use the module with a pressure sensor and the lm35dz, but are unsure about the compatibility.
Tia
Posted: Tuesday 13 February 2018 8:54
by emme
following the fibaro logic... it could be that once you connect the temp sensor you have to exclude and re-include the device in the zWave Network
(for door sensors it works like that :( )
