Problem FGMS001-ZW5 no LUX or TEMP device
brommetje
Post by brommetje »
Hi all
Just bought an Aeon Gen5 Zwave controller (v3.2) with a Motion sensor FGMS001-ZW5. Problem is that only device id 200, 232 and 235 is recognized.
Installed/compiled OpenZwave 1.4-2435, Domoticz version 3.6953.
So only motion is working, problem is Lux device created but not updated and NO Temp device created, any one a idea?
Martin
tontze
Domoticz version: Beta Ch
Re: Problem FGMS001-ZW5 no LUX or TEMP device
Post by tontze »
Reset it, and include again. Usually it helps.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
brommetje
Post by brommetje »
Tontze, it is working now, after deleting the sensor and adding the sensor again I had the same problem no lux and temp device. But after about 1,5 hour the lux and temp device was there and it is working now.
Strange that it takes so long.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Values are only sent when the defined treshold is passed.
tontze
Post by tontze »
Egregius wrote:Values are only sent when the defined treshold is passed.
True, but devices should still be there before first value send right ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Egregius
Post by Egregius »
No, devices are created with first value. Keep in mind that accept new hardware must be enabled.
brommetje
Post by brommetje »
In my case Accept New hardware is enabled by default devices created about 1,5 hour later.
