Unhandled switch command?
Posted: Tuesday 14 March 2017 13:28
by olskar
Hi!
Get lots of unhandled switch command-errors in my log. What is this? Running R46 of RFlink and latest beta on Domo.
2017-03-14 13:19:16.402 Error: RFLink: Unhandled switch command: 0
2017-03-14 13:23:50.018 Error: RFLink: Unhandled switch command: 0
2017-03-14 13:24:24.128 Error: RFLink: Unhandled switch command: GOUP
2017-03-14 13:26:19.673 Error: RFLink: Unhandled switch command: 0
2017-03-14 13:26:41.414 Error: RFLink: Unhandled switch command: 0
2017-03-14 13:26:59.035 Error: RFLink: Unhandled switch command: GOUP
2017-03-14 13:26:59.670 Error: RFLink: Unhandled switch command: 5
2017-03-14 13:27:16.151 Error: RFLink: Unhandled switch command: 0
Re: Unhandled switch command?
Posted: Monday 28 May 2018 8:24
by DutchHans
I am having exactly the same...
2018-05-27 10:18:23.160 Error: RFLink: Unhandled switch command: E
2018-05-27 13:16:07.921 Error: RFLink: Unhandled switch command: GODOWN
2018-05-27 13:29:18.376 Error: RFLink: Unhandled switch command: E
2018-05-27 13:30:37.125 Error: RFLink: Unhandled switch command: 6
2018-05-27 13:31:56.443 Error: RFLink: Unhandled switch command: GODOWN
2018-05-27 13:37:12.345 Error: RFLink: Unhandled switch command: E
2018-05-27 13:38:31.302 Error: RFLink: Unhandled switch command: E
2018-05-27 13:41:09.234 Error: RFLink: Unhandled switch command: 4
2018-05-27 14:04:50.960 Error: RFLink: Unhandled switch command: E
2018-05-27 14:36:27.349 Error: RFLink: Unhandled switch command: 2
2018-05-27 14:46:59.181 Error: RFLink: Unhandled switch command: E
2018-05-27 15:09:22.243 Error: RFLink: Unhandled switch command: E
2018-05-27 15:52:49.545 Error: RFLink: Unhandled switch command: GODOWN
2018-05-27 16:02:02.324 Error: RFLink: Unhandled switch command: GODOWN
2018-05-27 16:17:50.097 Error: RFLink: Unhandled switch command: 4
2018-05-27 16:19:09.314 Error: RFLink: Unhandled switch command: GODOWN
2018-05-27 16:21:47.418 Error: RFLink: Unhandled switch command: GODOWN
2018-05-27 16:38:54.181 Error: RFLink: Unhandled switch command: 6
2018-05-27 16:41:32.195 Error: RFLink: Unhandled switch command: 4
2018-05-27 17:42:06.470 Error: RFLink: Unhandled switch command: 6
2018-05-27 17:48:41.620 Error: RFLink: Unhandled switch command: E
2018-05-27 18:03:10.705 Error: RFLink: Unhandled switch command: GODOWN
2018-05-27 18:11:04.190 Error: RFLink: Unhandled switch command: 4
2018-05-27 18:13:42.625 Error: RFLink: Unhandled switch command: 2
2018-05-27 18:26:52.675 Error: RFLink: Unhandled switch command: 4
2018-05-27 19:27:26.366 Error: RFLink: Unhandled switch command: GODOWN
2018-05-27 22:59:25.746 Error: RFLink: Unhandled switch command: E
2018-05-27 23:00:44.928 Error: RFLink: Unhandled switch command: E
anyone an idea where this is coming from... ?
it came out of the blue several days ago.
It is very annoying,
regards, Hans
Posted: Friday 10 August 2018 15:41
by bjornhallberg
I'm also having a similar problem. Seems very intermittent. Rflink seems to be working otherwise.
2018-08-10 15:02:33.491 Error: RFLink: Unhandled switch command: 00
2018-08-10 15:04:22.392 Error: RFLink: Unhandled switch command: 00
2018-08-10 15:05:01.348 Error: RFLink: Unhandled switch command: 00
2018-08-10 15:05:19.361 Error: RFLink: Unhandled switch command: 00
2018-08-10 15:05:22.847 Error: RFLink: Unhandled switch command: 00
Posted: Friday 10 August 2018 15:55
by SweetPants
I'm on latest Beta also but RFLink R48.4. Maybe upgrade RFLink first. Don't see those messages in the log
Posted: Tuesday 04 September 2018 17:00
by bizziebis
2018-09-04 16:30:34.428 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:30:47.482 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:31:12.397 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:31:19.826 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:31:30.500 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:31:33.817 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:31:39.531 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:31:41.256 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:32:13.879 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:32:14.562 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:32:16.587 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:32:22.284 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:33:54.870 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:33:57.962 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:34:06.736 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:34:29.549 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:34:33.096 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:34:39.572 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:34:46.450 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:34:56.185 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:35:00.641 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:35:02.432 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:35:06.679 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:35:11.819 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:35:18.802 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:35:39.916 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:36:38.241 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:36:45.380 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:36:49.828 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:37:26.219 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:37:43.050 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:37:52.405 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:37:55.870 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:38:27.060 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:38:29.284 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:38:47.547 Error: RFLink: Unhandled switch command: GODOWN
2018-09-04 16:38:57.688 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:39:25.380 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:39:44.376 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:39:47.387 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:39:50.881 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:39:51.438 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:40:11.335 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:40:31.245 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:40:38.840 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:40:49.964 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:40:51.332 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:41:16.242 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:41:25.118 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:41:45.306 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:41:48.285 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:41:49.709 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:41:56.657 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:42:00.458 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:42:02.375 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:42:26.126 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:42:29.317 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:42:37.311 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:42:41.002 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:42:50.869 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:42:59.130 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:43:30.120 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:43:42.411 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:43:55.894 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:43:57.332 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:44:08.464 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:44:13.494 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:44:36.186 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:45:06.282 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:45:41.416 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:45:49.489 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:45:52.929 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:46:01.551 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:46:25.859 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:46:36.377 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:46:42.554 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:46:44.320 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:47:04.553 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:47:16.168 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:47:54.134 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:49:07.609 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:49:24.505 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:49:29.788 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:50:00.318 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:50:18.180 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:50:45.307 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:50:58.872 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:51:40.355 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:52:06.782 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:52:21.862 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:52:29.772 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:52:59.798 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:53:32.344 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:53:39.585 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:54:00.904 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:54:12.467 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:54:21.370 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:54:46.839 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:56:11.271 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:56:31.124 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:56:39.724 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:56:40.302 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:56:49.993 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:56:52.778 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:56:53.917 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:56:55.859 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:56:56.824 Error: RFLink: Unhandled switch command: GOUP
2018-09-04 16:57:32.410 Error: RFLink: Unhandled switch command: 00
2018-09-04 16:57:38.456 Error: RFLink: Unhandled switch command: 00
Same here..
So my neighbors like to play with their blinds, but it floods my logs. Very annoying for a device which is not even in my device list
RFLink Version: 48.4
Maybe add this message as a debug message? Not as a standard error message..
Posted: Wednesday 26 September 2018 9:24
by bizziebis
I opened an issue on GitHub but that was closed an I was redirected here.
Back to were it started and where the problem remains
Posted: Wednesday 26 September 2018 10:02
by Justinb81
Yes indeed, as if it is an RFlink problem. The firmware hasn't been updated in a year
Posted: Monday 08 November 2021 9:56
by BB88
Any solution yet? It is really annoying that this is flooding my error log
Posted: Sunday 14 November 2021 19:21
by vodor
Does this error come up even when you have "Accept new Hardware Devices" disabled? That's the only suggestion I can think of.
