Add library to lua : raspberry
Posted: Monday 13 March 2017 15:43
I instaled the librs232 library in the raspberry along domoticz. (home/username/ folder). When I call
I get
How can I include the "home/username/librs232/dist/lib" to the domoticz path variable ?
I set the $PATH environoment variable on rasberry debian jessie. But the error is still prompted in the domoticz log.
require("luars232")Code: Select all
no field package.preload['luars232']
no file '/usr/local/share/lua/5.2/luars232.lua'
no file '/usr/local/share/lua/5.2/luars232/init.lua'
no file '/usr/local/lib/lua/5.2/luars232.lua'
no file '/usr/local/lib/lua/5.2/luars232/init.lua'
no file './luars232.lua'
no file '/usr/local/lib/lua/5.2/luars232.so'
no file '/usr/local/lib/lua/5.2/loadall.so'
no file './luars232.so'I set the $PATH environoment variable on rasberry debian jessie. But the error is still prompted in the domoticz log.
