Relay Switch 433mhz like Fibaro
bigpea
Post by bigpea »
I would buy relays compatible with RFXCom 433mhz, recessed into the wall (like fibaro), in order to set on/off my light via domoticz or via physical button.
Do you have any suggestions?
tontze
Domoticz version: Beta Ch
Re: Relay Switch 433mhz like Fibaro
Post by tontze »
Problem with these are that when switching physically, they dont update state in domoticz .. Attleast i havent found a single one that will send status when changed...
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
sisaenkov
Domoticz version: 3.8
Post by sisaenkov »
bigpea
Post by bigpea »
oh very nice, thanks i will see with more attention! thanks.
tontze
Post by tontze »
Thats interesting =)
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
mjdb
Domoticz version: all beta
Post by mjdb »
A do-it-yourself Relay Switch with return-channel...
viewtopic.php?f=56&t=17656
If your wall is big enough, you will get it in.
2 x Domoticz on Raspberry Pi; 2 x RFXtrx433; Aeotec Z-Stick
KlikAanKlikUit ICS-2000 as Relay
Aeotec MultiSensors 6; Danfoss Z Thermostats 014G0013; Kaku Switches, Z-wave Switches
