Search for file 'js/graphs.js' in your installation of Dashticz. Now search in this file for the function 'makeMorrisGraph'. Change the 2d line from 'Morris.Line' into 'Morris.Bar'.
HenriM wrote: ↑Saturday 18 May 2019 9:48
You're my hero, is this something that should be in the Wiki? Who does the updates of wiki anyway?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
gielie wrote: ↑Monday 20 May 2019 10:40
Everybody can do updates to the wiki (feel free:) to add this), do keep in mind (/mention) this change will be lost on upgrading dashticz.
I understand this will be lost during an update, is it an idea to put this in the setting? I dunno if that is easy to do.
Im now looking a way to show my electricity use and collection, now its combined in P1 and I want to show the use and delivery in 2 separate graphs. I found the wiki about the different graph types but I can't figure out how to separate these. Like (graph_5_1) like I can do with a temp/hum sensor, any ideas?
- FIBARO FGS223
- Toon
- Kodi Media Server
As of 2 releases back from Domoticz P1 meter has to extra device as in P1 Usage and P1 Delivery.
Saves you (and me recently) to split the combined graphs.
Goodluck adding them.
Stephan
This is great but i cant find this option. Can you point me to some documentation?
- FIBARO FGS223
- Toon
- Kodi Media Server
Not sure which wiki you need to check. Updates Domoticz bèta 2 month ago. And the P1-meter had magically 2 extra device (device-tab) within Domoticz.
Activate/Enable these first in Domoticz. Record the idx-numbers And adjust your CONFIG.js for Dashticz to include those, instead of the combine P1-smartmeter.
This way they act as a regular device like temp or barometer device in Dashticz.
stlaha2007 wrote: ↑Saturday 25 May 2019 11:41
I dont have this in my Domoitcz (also latest beta) nor can i find any documentation on this. Anyone else who can point me to the right direction?
- FIBARO FGS223
- Toon
- Kodi Media Server
Check your list of devices. They will be there, you only need to add them. Currently they will be logging already, so in the devices tab you can already see some results. Search for p1 and you will find some devices with a green arrow.
jake wrote: ↑Monday 27 May 2019 10:27
Nope i dont have it, cant find it, don't know what to do.
I only have my original 2 P1 sensors, the gas and the electricity but no split up in used/received
I cant find the release notes of the latest betas where it is explained.
- FIBARO FGS223
- Toon
- Kodi Media Server
Strange. I've got 4 P1 devices right from the moment I added the hardware. Maybe let it discover again. Disable the hardware, let . domotic search for new hardware, then enable the P1 hardware. That is what I did.
EdwinK wrote: ↑Tuesday 04 June 2019 15:11
Tnks edwin for the reply, i think the problem is that it is not a hardware device but a dummy device who uses the data from my Toon. Mayby i have to rethink my Toon script. Which Toon script are you using at the moment?
- FIBARO FGS223
- Toon
- Kodi Media Server
None, for what ever reason none of the scripts are working. I even had it that when I was creating the UserVariables for one of them, my domoticz hanged and became unstable.
