List USB (ttyACM) devices by id
Posted: Thursday 09 March 2017 13:04
Please add support in the tty/serial/usb drop-down lists to select from id's instead of 'hard' ttyACM0/1/2...
The list in /dev/serial/by-id/ contains links to the appropriate ttyACMx.
This helps when the device is moved to another slot and thus can change ttyACMx -> ttyACMy and make Domoticz fail to connect.
Using ids this problem is removed.
Thanks,
Mikkel
Thanks,
Mikkel
