SolarEdge web API, nothing happens when 'add' is pressed
JuanElCapitano
Post by JuanElCapitano »
I installed the latest version of domoticz (3.6882) and try to add my SolarEdge via web api. However when I enter the API key, give it a name and press add nothing happens. I don't see anything happening in the log file.
I succesfully evaluated the API key using the url: https://monitoringapi.solaredge.com/equ ... OUR_APIKEY
Adding other hardware does work.
simonrg
Domoticz version: 3.8807
Re: SolarEdge web API, nothing happens when 'add' is pressed
Post by simonrg »
Is it dark with you now?
The devices will only update when your inverter is powered up, i.e. during day time.
So I think you might find it all appears tomorrow morning.
JuanElCapitano
Thank you for your reply. Unfortunately nothing happens during 'Energy Production' as well when I press the add button in the Setup> Hardware page. The list of hardware is refreshed, but the inverter is not added.
gizmocuz
Post by gizmocuz »
Sorry, my fault.
The solaredge class has been rewritten this week, we support multiple sites and only the API key is needed now.
If you update to beta #6935 or higher, you can add/edit/delete the hardware now
